I have a VIZIO LCD TV Model voj320f1a, it will not come out of standby mode(vizio logo is on constantly orange/amber color. I've tried the unplugging it, for seconds and minutes with no success. The color never changes. I also do not have a remote for it. I don't know if that is relevant or not. All the caps on the pwb looks good, solder joints are good. Any ideas what is wrong with the TV? Please help. Thanks
I've tried the rest issues, no fix or change, all the capacitors are good and isn't a pwb problem. I am a certified tv tech but have never faced this issue. I am leaning either toward the main board or the Tcon or inverter board. Any other suggestions that MIGHT ACTUALLY work instead of the same answers that some of you post for every problem...ie, leaking or bad capasitors DO NOT fix all problems. Thanks you for any REAL help that I might receive.I've tried the rest issues, no fix or change, all the capacitors are good and isn't a pwb problem. I am a certified tv tech but have never faced this issue. I am leaning either toward the main board or the Tcon or inverter board. Any other suggestions that MIGHT ACTUALLY work instead of the same answers that some of you post for every problem...ie, leaking or bad capasitors DO NOT fix all problems. Thanks you for any REAL help that I might receive.
You can't post conmments that contain an email address.
? 6:13
https://www.youtube.com/watch?v=9xZcTWr2yV0
Nov 5, 2013 - Uploaded by Tampatec
DiY How to Fix led / lcd Vizio TV service repair - no powerservice repair review guide no red blinking led ... Theorange/amber light turns on when plugged in. But the TV won'tturn on after that (the light does not turn white).
? 4:01
https://www.youtube.com/watch?v=MDzCzZdgbdg
Jan 5, 2012 - Uploaded by Leo P
This is model XVT3D424SV, I was watching a DVD, I switched the input to TV, tried to connect to netflix, it was ...
? 6:21
https://www.youtube.com/watch?v=B_ae3f7C3jQ
Feb 20, 2012 - Uploaded by Brady Smith
Learn how to replace your LCD Visio TV motherboard and hear a few facts ... ANYBODY KNOW HOW TO FIX OR WHAT NEEDS TO BE FIXED IF THE ... I have found that I need to replace themainboard in my vizio 42 inch. .... hey, man. can you help me out? i got a VIZIO E3D320VX from ebay brand new.
? 2:48
https://www.youtube.com/watch?v=a_8URZW356E
Dec 6, 2012 - Uploaded by ShopJimmy.com
Top Common Vizio LCD TV problems for bad Main Unit Boards:... To be best prepared to replace the Main Board inside of yourTV, you will need the following ... If you have any further questions regarding your repair, simply post a ... i can see on one of the small black squares (sorry i dont know what they ...
Vizio logo is an indicator that the tv is live n changes to white that the screen is on meaning if no change to white the smps switch mode power supply board ain't switching the mother board....diagnosis is its MOSFET transistors need replacement or the smps board n ya tv will be fine
If the Vizio logo(power indicator) isn't coming on when the set is plugged in, most likely you have a issue with the power supply. Your standby power supply isn't working, and without it, you will have a dead set.
Check all electrical connections. If standby light is off when plugged in, probably needs Power Supply board replaced. If standby light is on (Orange/Amber color) may need Power Supply board and or Main Board. If set was shutting down on it's own leading up to it not powering on at all, may need Main Board, and possibly Power Board as well. If standby light has changed from Orange/Amber color to Green, the set IS powered on, and you have an issue other than power.
