Question about Champion International Champion Power Equipment 46515 3500 Watt 196cc OHV 4cycle Gas Powered Rv
My powerlift automotive GG3500 brushless generator puts out 91 volts at 3600rpm, if I increase rpm to around 4300rpm it then puts out 120 volts. WHY!
Posted by Charles Moore on
Honda ex5500 generator over voltage output
adjust the rpm back to 115-120 volts
or increase voltage to 220-245 volts
Nov 25, 2017 | Honda Electrical Supplies
How to increase the output voltage
Measure the Generator after 10 minutes the first measure but not only to one power outlet with doing a measure with a multimeter its not done so because the generator is fully unloaded then you will see 105 vac
Measure on one outlet and use a paint stipper a 2000 watt type and measure at the same time on the second power outlet with a multimeter on AC you should get more volts out to measure instead of 105 volts then you hear that its generate power and blow more smoke you will be seen a 115 or 120 volts if you increase this generator its possible you get if you are increase the idle power to 120 volt can create an over loading of 200 volt or more over the outlets that can give damage if it the stator electric field generate power outside its level it can blow up your expensive tools and in a short time you think there is not enough power on my tools anymore then your armatures are become bad and the tools are hot in a short time warmt dissipation has blow up armature and nothing smels hot but the tools are blowing up. and you see nothing inside because the tools will not are getting black burned and hot but the to high magnetic pulse burns the weak points inside the armature in a fraction of time.
Beware of that the adjusting is normally doing with a tacho meter and a suggestion of about 3000rpm and not more of the stator what its max depend on model . but adjust by the load power of a working paint stripper it can have enough if you adjust 120 volt by load.
Mar 06, 2016 | Electrical Supplies
Coleman vertex 7500
The capcitor needs checking in the end of the alternator
Oct 03, 2013 | Electrical Supplies
Troy Bilt 8000 watt generator is not puting out full 120 Volts after converting to run on propane.
if the rpm's are not right the voltage regulator can't put out more than its putting out
May 28, 2012 | Garden
Briggs and stratton 8000 watts generator, the output of the 120 is only 102. How do I adjust the output?
Voltage is adjusted by increasing rpm of engine. Use meter with Hz setting and try to adjust to 60 cycles and check voltage to be at about 115-120. If engine is turning 3600rpm/60 cycles and voltage is very low, then problem is most likely with brushes/ commutator rings, or voltage regulator. Some voltage regulators have an adjustment screw to bring voltage up/down (adjust to proper rpm/cycles first). Good luck
Sep 09, 2010 | Briggs & Stratton Electrical Supplies
My generator is not putting out the proper voltage? it's only putting out approx 75 volts on the 120 volt circit. i adjust the idle to full out and i get approx 112v.
Most low voltage conditions on generators are simply due to a low engine rpm. Most modern generators are 2- pole windings. So your engine rpm should theoretically run @ 3600 rpm. which will produce 120/240 volts @ 60 HZ. In actuality You want to set your rpm's @ Approx. 3720rpm no load. About 62.5 Hz. Without getting to technical this will give you your desired 120/240 volts loaded. Hope this helps.
Aug 09, 2010 | Northstar Electrical Supplies
I disassembled my EM650 Generator and to clean out
Most generators (except the latest inverter generators)
produce power directly dependent on RPM's.
The governor adjustment is critical.
This usually is in the form of an adjuster that through a spring, applies a preload to the governor arm.
The governor arm is attached to a shaft that disappears into the motor. Inside there is usually a set of weights that when spun faster will attempt to slow the motor and when spinning too slowly will attempt to increase revs. The adjustment you need to make is to the preload spring.
They are very sensitive to the motor being in good tune so do the air cleaner, spark plug etc before trying to get it right. Under voltage can do more damage than over voltage so take your time and get it to a good steady correct voltage with your usual expected load on it. A safety trip out box gives you a way to test voltage with a load on & some protection.
Work safe
Oct 15, 2009 | Electrical Supplies
Have a gg3500 gas generator that give no current
you need to check to make sure you have no power out put, check all receptacle. if none check your owner Manuel on how to flash your unit. you may want to check all breakers. if flashing don't work take it to repair center to check stator and rotor
Oct 03, 2009 | Electrical Supplies
Engine running at 3600 rpm i get 0.51 volt reading from all scocket outlets
check your volt-meter..if it works...then find out if 3600rpm is normal for that kind of generators...if so...check AVR card...its allways the problem...replace it
i hope i helped...send me an email for more details
Oct 01, 2009 | Electrical Supplies
Low voltage
Most generators use a flyball type governor within the engine to control rpm; also there is a voltage regulator that tries to maintain voltage at about 115v. The voltage regulator varies the voltage to the armature increasing /adjusting magnetic force. Use a meter with htz or freq setting to adjust engine governor to 60 cycles. When the generator is producing 60 cycles, the engine should be turning 3600 rpm, max power range. At 3600 rpm the voltage should be 115 to 120 volts. Loading the generator will cause governor to try to maintain 3600 rpm. Check engine manual for proper adjustment of gonvernor and linkage. The governor mech should last the life of the engine, however governor system does wear out. Expensive repair. enjoy
Nov 26, 2008 | Yamaha Electrical Supplies
Champion International Champion Power Equipment 46515 3500 Watt 196cc OHV 4cycle Gas Powered Rv Logo
161 people viewed this question
Top Champion International Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Champion International Electrical Supply Expert? Answer questions, earn points and help others
