Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
Sandy Posted on Sep 25, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a frigidaire gallery glass stove top that is about 5 years old. I can't locate the book that came with it... I want to use the self clean and don't know how to. Also, I don't have a door lock on this model. Can someone tell me what button or whatever you set to to the self clean? It has a clean button and a speed clean button.. Thank you for your help.
  • Official Brand Answer 4,342 Answers
  • Posted on Sep 26, 2013
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1466991
Points
5907
Good Morning Sandy, thank you for allowing me to assist you!
I understand you are seeking information regarding the self-clean feature for your above-listed range model number, GLEFM397DS. I have located the Owner's Guide on the manufacturer website and you will find step by step instructions on how to do so from pages 32 through 34. Hope this proves helpful! If you have further questions, please do not hesitate to reconnect.
5 Related Answers
Anonymous
  • 150 Answers
  • Posted on Apr 22, 2008
SOURCE: frigdaire gallery stove
lock mechanism is acting up. happens sometimes. you can get to it from the back and get the thing open to use until you get the part
Anonymous
  • 1314 Answers
  • Posted on May 24, 2008
SOURCE: Clean Oven Door Glass
To remove oven door:
1. The oven door is held to the oven door hinges by two
screws. (One in each hinge.)
2. To remove the oven door remove the two screws.
Two screws
3. Close the door to the broil stop position and lift up.
then remove the door handle and take out all the screws around the edges of the door and pull the out side cover from the inner but a word of caution there are about three or 4 pieces of glass they are tempered and about 100 bucks a piece and most times they wont get real clean and will get messy again
Anonymous
  • 750 Answers
  • Posted on Oct 14, 2008
SOURCE: The door on my frigidaire
Hello kmgtsg,
Welcome
You said, The door on my frigidaire stove model # FEF389WJCC locked and we are unable to get it open. We weren't self cleaning the oven so I'm not sure what happened. Any suggestions how to fix it? We did try turning the breaker off and that didn't help.
Did you leave the breaker off for 5 minutes or just flicked it off and on?
It may be a faulty door Latch
The door latch consist of a micro switch and solenoid. Once the door is closed and the latch handle.
But first try to deactivate the door lock
Oven Lockout
To activate the Oven Lockout feature:
1. Press and hold for 3 seconds
2. After 3 seconds a beep will sound, LOC will appear & "DOOR
LOCKED" will flash in the display. Once the oven door is locked
the "DOOR LOCKED" indicator will stop flashing.
To reactivate normal oven operation:
1. Press and hold for 3 seconds. A beep will sound. LOC will
clear. The "DOOR LOCKED" will continue to flash until the oven
door has completely unlocked
2. The oven is again fully operational.
Let me know if these procedures work for you!!
Huuum,
Please remember to leave a rating!
Anonymous
  • 7 Answers
  • Posted on Jan 30, 2009
SOURCE: How to lite a pilot lite on a frigidaire "Gallery" gas stove?
wet sparkers, let them dry out good
Anonymous
  • Posted on Feb 18, 2009
SOURCE: self cleaning oven instructions
My oven is beeping and display F 1 what does this mean
Directions how to use self cleaning over on the fridge re gallery gas stove
Hello, Joan -
Clarification: You are asking about a Frigidaire Gallery model gas stove and how to use the self-cleaning feature for the oven? If so . . .
You will find the instructions here:
https://www.hunker.com/12002208/instructions-for-a-frigidaire-gallery-series-self-cleaning-oven
If you need the user manual for your oven, you can add the model number by choosing Comment and adding the information there, so I or someone else volunteering to answer on Fixya.com can look for and provide the right link for a download of a free manual.
Note: There is more than one Frigidaire Gallery range model numbers made:
https://www.frigidaire.com/Kitchen-Appliances/Ranges/View-All/?filter=Feature02012:Feature02012
Best wishes.
4answers
Where are the fuses located in a frigidare stove
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
Frigidaire electric stove does not work at all
First check the breakers at your house's breaker box. A tripped breaker will be a little bit away from on. Push it all the way off, and then back on. If it trips again, call an electrician.
The inside glass panel, in the oven, has a hairline crack. Is the oven still usable?
Hello ewaters56 - Honestly, I suggest contacting a professional to have the inner glass panel replaced and I do not recommend for the oven to be used.
Oven door won't open after self-cleaning. Open it
Unplug the range.
Remove the back panel.
Look for the long rod going from the back to the front of the oven.
Manually push on this rod to unlock the door.
2helpful
How do I raise the cooktop on my Frigidaire Gallery Model #GLGF377ASE . I need to access the burner orifices.
If you raise up the top you will break the tubing going to the burners. You must remove the screws on each sealed burner before raising the top. Look closely and you will see the screws. They will be hard as heck to come out. If a stove is real old and I cannot get the screws out I dremmel the screw heads out and drill out the screws. I do a repair and then pop rivet the burners back on. If I have to go back in there it is nothing to drill out a pop rivet. That is how I do it on real old stoves. You may figure out a better way. You have to get those burners loose or you will break those lines below the top.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Frigdaire gallery stove
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
