Magnavox 19md350b/f7 19-inch 720p Lcd Hdtv With Built In Dvd Player, Logo
melissa Posted on Sep 25, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need a stand for a magnavox md350b/f7 - Magnavox 19md350b/f7 19-inch 720p Lcd Hdtv With Built In Dvd Player,
Level 3:
Top Expert:
  • Magnavox Master 76,851 Answers
  • Posted on Sep 26, 2013
Magnavox Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14988714
Points
237762
Contact the authorized dealer for Manavox.
1helpful
Find wireless headphones for magnavox 32mf301b/f7
Magnavox support page:
https://www.philips.ca/c-p/32MF301B_F7/-/support
You could use ebay.com or amazon.com to check for wireless headphones for sale online.
Visit the support page for your Magnavox 32MF301B F7
Can't get picture on Magnavox MD350B. Not getting any response from the remote have to unplug it to turn it off.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
What size screws do I need for the table top stand?
Google the model number searching for user manual or if you have the manual look in the front pages. One page should have the contents that came in the box and the assembly instructions. Screw sizes will be there.
3answers
Need to find out a part # for my philips 52PFL7403/f7 for the ir sensor
Join Date: Nov 2011 I have a Philips 47PFL3603D/F7 with the same problem. It was the IR sensor board causing the problem. You can search online to find the board, which almost everyone will most likely not have in stock, and cant be ordered. The part you need is this: 313926859181 IR Remote Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3403D/F7
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about $12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to do this if you can spin it around to gain access to the back of it. Be sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower left side by the speaker. It will have 2 cables attached to it. Remove them, and take out the screw or two that holds it in place. There will be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come free. After that you should be holding the board in your hands. The side of the board with the connectors on it is the side you want to manipulate. There will be a tiny surface mounted capacitor beside one of the wire connection sockets. Take a utility knife and scrape it off/ you could use a soldering iron but it should come off very easy with a knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
Top Magnavox Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
