Question about Acer Computers & Internet
There is no print icon on the tool bar - Acer Computers & Internet
Posted by milton reine on
Brian Sullivan
  • Acer Master
  • 27,725 Answers
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Then from the file drop down list print preview and print
Posted on Sep 26, 2013
Lexmark x1185 not printing all the page
In this case what i would Request u to do is.........
Goto Control Panel goto Printers folder.........
There u will see the Lexmark Printer Icon...........
Just right click on the Printer Icon and click on Properties.........
Now click on Advanced and goto Print Processor.........
Change it to Lexmark NTEMF 1.0008........
Click on Apply click Ok now try to Print..........
Prints Fine............Issue Resolved........
Same Problem........
Download the Lexmark ToolBar from:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1255995709_0_en,00.html
Restart your computer once and now try to print using the Lexmark Tool Bar..........
It should work fine........
Good Luck..............
Apr 13, 2013 | Lexmark JetPrinter X1185 All-In-One InkJet
I can print out e-mails just fine using the print icon. There is no print icon on my drafts so I can't pint them before I send them. The print icon used to be there, what happened?
Go to tool bar menu setting in option.
Now you will see new window then drag print button on the bar just parallel to address bar. drag it to there,
Nov 11, 2011 | Google Chrome
WHEN I WONT TO PRENT MY PRENTER TOLD ME THAER IS NO SOFTWER MY PRODUCT : oPTRA t 610 WHEN I WONT PRENT I TURN OFF & ON oR OBEN THAE DOOR
Default Printer Issue
The wrong printer is set as the default. See the image below for an illustration.
What to do
Open the Printers or Printer and Faxes folder and locate the correct printer icon. To do this:
    1. -In Windows XP, click Start > Settings > Printer and Faxes (or Start > Control Panel > Printers and Faxes).
      -In Windows Vista, click Start > Control Panel > Hardware and Sound > Printers.
    2. Right-click on the printer icon, and click Set as Default Printer. A check mark displayed above the printer icon now identifies it as your default printer.
    3. Try printing again.
Topic 3: Printer is "Offline"
The printer is set to Offline and the printer icon appears washed-out. See the image below for an illustration.
What to do
  2. Right-click on the printer icon, and select Use Printer Online.
Topic 4: Printer is not Ready
The printer is in an "Intervention Requested" state (e.g. paper jam, paper out) but no Windows print error notification message is displayed.
Explanation
The print job cleared the print queue. This means the print queue icon has disappeared from the notification area ('systray') of the task bar. The printer is holding the job, however, until the the printer is returned to a ready state.
What to do
Check the printer LCD, or operator panel menu, to verify that the printer is in a ready state. If not, return it to the required status.
Topic 5: Printer is Paused
The printer or print queue is paused and the print queue icon remains in the notification area ('systray') of the task bar.
Explanation
This is typically an end user error. Dragging the mouse cursor over the print queue icon in the notification area will reveal (1,2,3) document(s) pending for (User name).
What to do
    1. Double-click on the print queue icon to open the print queue. (This may also appear as a small printer icon in the lower-right notification area of the task bar.)
    2. Click on Printer in the upper left-hand corner of the menu bar.
    3. Is there a check mark next to Pause Printing?
      -If yes, click on Pause Printing to turn off this Windows feature.
      -If no, confirm that there is a check mark next to Set As Default Printer and make sure Use Printer Offline is not selected.
Topic 10: Windows Print Spooler Issue
A problem with the Windows print spooler is preventing successful printing.
What to try
Stop and start the Windows print spooler. To do this:
  • -In Windows XP, click Start > Control Panel > Administrative Tools > Services, click on Print Spooler, click on Stop the service, and then click on Start the service.
  • -In Windows Vista, click Start, type services.msc in the Start Search box, and then click services.msc in the Programs list. Right-click on Print Spooler, and then click Stop. Finally, right-click on Print Spooler again, and then click Start.
Remove the first print job from the print queue. To do this:
  2. Click on the first job listed so that it is highlighted.
  3. Click on Document in the top menu bar.
  4. Click on Cancel.
  5. Click Yes when you see: "Are you sure you want to cancel the selected jobs?"
Click here for illustration.
Topic 11: Other Issues
Other possible causes of a print job not printing include:
  • -USB connection problem if locally connected only.
  • -Firewall issues preventing communication.
  • -Workplace virtual private networks (VPNs) preventing communication. VPN tunneling may be required to ensure successful communication. Enabling this feature may require network administrator approval and assistance.
  • -Document formatting.
  • -Driver settings.
  • -Application-specific issues relating to the application's Printer Setup.
Topic 12: Last Resort
If you have tried all of the above suggestions to no avail, try the following:
  1. Reboot your computer and try printing again.
  2. Turn the printer off and on, and then try to print again.
  3. Install a different printer driver, e.g. PCL, PostScript, HBP, or XPS driver.
Dec 14, 2010 | Lexmark Optra T610 Laser Printer
How do I change the text size On Internet Explorer
In the Windows Explorer window, look at the tool bar to the top right of window, where you see the Home icon, and Print icon etc.. One of these is Page.
IF you don't see these.. Right click on the gray tool bar area, and click on Command bar to activate it. Click on Page, and the drop down menu will include Text size option.
If you don't see Page as option, click on the little >> sign to expand hidden icons.
Dec 11, 2010 | Google Chrome
I need the owner's manual for Kenmore for model 11206. I can't find it anywhere on the net! I will be grateful for even a scanned copy from someone!!! help!
Hi and welcome to FixYa, I am Kelly. I used this model number to find a manual. 385.11206300
It can be viewed and downloaded here: http://www.managemylife.com/mmh/owner_manuals/20676/KENMORE-Mechanical-Sewing-L0305018?brand_name_search=38511206300+KENMORE
Use the 2nd icon from the left on the tool bar at the top of the document to save the manual to your computer or the First icon on the tool bar to print a copy.
Thanks for choosing FixYa,
Kelly
Nov 15, 2010 | Kenmore 11206 / 11306 / 11506 / 11606
I want a printer icon on my internet tool bar inorder to print net webpages
i want to put a printer icon on my internet toolbar so i can print info off the internet. how do i do it simply?
Dec 18, 2009 | ASUS WL-500g Wireless Router (WL500GDLX)
What does the print spooler service is not running mean?
Things You'll Need:
  • PC computer running Windows XP or Vista
  • Logged in with the administrator account
  1. Go into the Start Menu and click on the "Control Panel" icon.
  2. Double-click on the "Administrative Tools" icon in the pop-up window.
  3. Double-click on the "Services" shortcut icon, which will open a full list of all available computer services
  4. Use the scroll bar on the right side of the window to find the "Print Spooler" options.
  5. Click on "Start the Service" to turn on the printer spooler and allow printing to begin again. Regards
May 02, 2009 | HP PhotoSmart 7550 InkJet Printer
Unable to print from web on Lexmark z2300
hi ..
log on to lexmark website..www.lexmark.com ...downloaded lexmark tool bar to ur desk top ...once download is complete .install tool bar...then open web page..don not print from file..instead use the printer icon on the top right corner to print...this should fix it
good luck
Feb 12, 2009 | Lexmark Z2300 InkJet Printer
Writing text
Most Adobe software does not have an icon for printing, you must select the first menu on the top left: "File," and then on the menu that pops up, select, "Print..." Alternatively you can hold down the Control key on a PC or Command key on a Mac and press, "P" and it will open the print dialogue box.
Hope this will FixYa!!!
Mar 25, 2008 | Adobe InDesign CS2 for PC
Computers & Internet Logo
212 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
