SOURCE: PCG-8P3M starting problem
Hi there
plug an external monitor to the laptop to rule out the inverter
post back
SOURCE: sony vaio pcg-grt170 when I push the power button,
Perform these steps and the issue will be resolved if the issue is with the Static charges on the Mother board.
I recommend you use Power Drain procedure by following these steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
SOURCE: sony vaio pcg-r505el won't turn on
These are know to have issues with the cpacitors on the mother board, you can try to replace the caps or just buy a new motherboard. I'm fixing one right now as I type...
SOURCE: Sony VAIO Laptop won't turn on. The power lights
Unplug from A/C adapter & remove battery and let sit fo a while..
Put battery back and plug in the A/C adapter, then turn back on.
SOURCE: my vaio will not turn on. The green light and
if still no go, unit needs service
