Question about Targus AKB33US Bluetooth Wireless Keyboard
The keyboard connects nicely to my Samsung Note 10.1 tablet, but every time I type the letter O, it inputs a double O on the screen ... As in, "woork" ... Very frustrating. Can anyone help?
Posted by Paul Husselbee on
2answers
My pad will not type what I press on the keypad correctly
Did you try turning it off and back on, or in the notification area do you see a tiny little keyboard? If so tap on it and choose Asus English Keyboard. Also make sure that the "Use physical keyboard" is marked ON.
My nook will'not change to numbers.stays on letters.any suggestions?
I assume you mean the Nook keyboard doesn't allow switching between numbers and letters. The built in Nook keyboard isn't the smartest or only keyboard app out there. Now that it's totally free strongly recommend you go into the Google Play Store and install SwiftKey. One hour using it and you'll wonder why you ever put up with Barnes and Nobles chunky idea of a keyboard. Even Google itself has their own keyboard app. You can have multiple keyboard apps installed at the same time. Just use the Switch Keyboard option to toggle between then.
As far as SwiftKey is concerned one of the main features that first sold me on it is it can be resized. I always hated the Nook keyboard just took up so much of your available screen space leaving so little for the input area. Did you know SwiftKey can be setup to show a numbers row at the top just like a regular PC keyboard? Also it can learn your typing patterns over time and predict the most likely word you will use next. Just click the word in the predictions bar.
2answers
1helpful
My keyboard on my eTablet doesn't want to "type" the letter everytime. I can start typing fine and then one of the letters will not show and I will have to sit there and play with the keyboard and fi
First, make sure that your screen is clean and clear of smudges/fingerprints, etc. Then try again. If still no go; possible static damage to capacitive overlay(time for phone repairman).
The "v" key is malfunctional. It does not input if I key it alone. The letter appears when I type a word with the letter v in it, but the spelling is wrong. It shows up after three letters or so. Sometimes...
Is this a laptop, phone, or a pc keyboard?
If it's a PC keyboard you might be able to pop the key out and clean under it. I have went as far to clean PC keyboards in the dishwasher. (low heat, no soap, no high temp dry... and then shake all excess water out... and let dry for a week or two.. before you plug it back up.) But do this at your own risk.
If this is a phone, and it is on a touch screen, then try going into settings and changing from samsung keyboard to default android keyboard.. or vice versa.
Keyboard double letter
Likely just a bad keyboard. Good news is that keyboard are really cheap for most laptops.
Viruses can do all kinds of weird things, they usually don't mess with the operation of the keyboard though.
1helpful
Samsung q45 keyboard intermittant
Try adjusting the keyboard input speed.
Go to Control Panel - Keyboard - Speed tab then adjust the speed settings.
HOW DO I CONNECT MY APPLE IPHONE TO PLUSNET WIRELESS
To type capital letters, press the shift key which is the up arrow in the bottom left corner of the screen, and then press the key for your desired letter. If you would like caps lock, double-tap the shift key. Note that the caps lock will be deactivated if you change to the number keyboard or symbol keyboard.
2helpful
2answers
Why i can't download yahoo messenger on my samsung galaxy tablet 10.1? Can you help me out
Here are the facts.
1. Samsung Galaxy 10.1 is running Android 3.1.
2. Yahoo messenger is ported till Android 2.2.
Solution:
1. You may have to wait for sometime time till Yahoo compiles IM in Android 3.1.
2. Use android 3.1 provided IM client to connect to Yahoo Messenger.
Targus AKB33US Bluetooth Wireless Keyboard Logo
Top Targus Computers & Internet Experts
Raj Patel
ADMIN Canada
ADMIN Canada
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
