Question about Hotpoint SY36 Style Line Stainless Steel Electric Single Oven
My hotpoint single oven wont heat up.the light will only go on when i turn to knob to light on..but it doesnt come on when i turn the knob for oven on and it doesnt heat up...until yesterday it was working fine--no problems
Posted by hilary kay on
fixitmaster
    Problem Solver:
  • 4 Answers
Hi there If everything else is working then it's probably the heating element They are not expensive to replace and can be fixed in less than an hr Hope this helps
Posted on Nov 22, 2013
5 Related Answers
Anonymous
  • 236 Answers
SOURCE: hotpoint BU62 bouble oven
sounds like the bott oven element has gone, or faulty thermostat.
Posted on Feb 16, 2008
Anonymous
  • 338 Answers
SOURCE: oven not heating
you could have lost one of your 120v leads to the machine. that could cause it to work only half way. go turn the breaker off and then turn it back on and see if that corrects the problem.
Posted on Dec 07, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: My oven wont heat up light and fan work I have
Even though the element look's o/k, it is more than likely faulty, more so if the fan is working o/k.
The only 100% test to make sure if it is faulty, is to test it with a meter.
In my experience I would advise you to replace the element.
Please rate my solution.
Thanks.
Posted on Nov 03, 2009
Anonymous
  • 213 Answers
SOURCE: my hotpoint oven is not heating up but hobb and
If you have a HOTPOINTelectric Cooker or Fan Ovenwhich is not heating it could be one of the following problems.
1, If the fanmotor inthe back of the oven is going round and the temperature light is on (normallylittle red light), but there is no heat then you will probably need a new ovenelement, these are generally very easy to fit and readily available from ourwebsite these can be tested with a electric meter.
To gain access to the HOTPOINTelement youwill have to remove the back plate from inside the oven. Once removed you willsee the fan and element,if you look closely at the element you will probably see a small hole burnt in it where ithas blown. Sometimes however there is no evidence of a fault but the element is open circuitie: broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your HOTPOINTfan oven is getting warm buttakes a very long time to cook or is burning the food more on one side than theother, then you need to check if your oven fanmotor is working you will seethe blade turning fast if it is ok. if the element is heating but the fanmotor isnot blowing the heat into the oven then you need To replace the oven fanmotor is a little more expensive and a bit moreinvolved.
3. If you have theopposite problem ie: your oven is over heating and burning everything then youwill need to replace your HOTPOINToven thermostat
4, A quite commonand easily overlooked answer is if your HOTPOINToven is not working at all ie:no heat and no fan then the chances are that someone has put the oven timer intoAUTO mode, simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 25, 2010
arepairman
Richard Saupe
  • 20 Answers
SOURCE: hotpoint sy36x grill element works fine but when
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
Posted on Mar 14, 2010
Hotpoint ew91 halogen hob wont turn off
the control may have shorted. replace control(behind the knob).
Sep 10, 2012 | Hotpoint Ovens
My oven wont heat up?
Hello there:
first chevck to see if the broil feature will work but if both the broil and bake feature does not work meaning it will not heat up if you have selected either the bake or broil follow these solutions that i have provided for you .
It won't bake or broil If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Jul 13, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
regards
richard saupe
appliance repairman
Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
My oven doesnt seem to work. No heat coming from it, light wont come on...
Its broken i suggest either claiming on your home insurance or get it repaired if it still under warranty
Aug 15, 2009 | Hotpoint Ovens
Hotpoint EG900X rear round heating element
If the fan is working, but there is no heat from rear element, then the element needs replacing.
Remove inner rear cover of oven, you will see the element there, remove, and replace.
Please leave a rating for my suggested solution.
Thanks.
Feb 17, 2009 | Maytag MEW6527DDS Electric Single Oven
Oven not heating
Hello.
If the fan is working, but there is no heat, then it is the fan oven element that needs to be replaced.
It has nothing to do with timer on this occasion.
Remove panel at rear of oven compartment, there you will see the round element.
Undo fixing screws,and remove element, disconnect leads and fit onto new element, refit new elemrnt, replace cover, and job done!!!
Please leave a fixya rating for my solution.
Thankyou
Feb 04, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Oven not heating
Dec 07, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Nov 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Hotpoint sy51x oven
your thermostat is on its way out it is place on the other side of the knob you will need a oven engineer to have a look
Jan 04, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Hotpoint SY36 Style Line Stainless Steel Electric Single Oven Logo
182 people viewed this question
Top Hotpoint Ovens Experts
Michael Thomas
Michael Thomas
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
