Bose Lifestyle 12 System Logo
Seth Darkcloud Posted on Oct 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not working Bose Remote My bose remoe actually
Not working Bose Remote My bose remoe actually works, when controling the system itself, such as a volume, cnanging input, etc. The problemis that it wont control the T.V. I suspect that it is just the signal receptor, as the system recently got sent in for repairs, andeverything else is fine. Any assurance and helpfor the roblem would be appreciated.
George Scott
Level 3:
Master:
  • Master 789 Answers
  • Posted on Oct 02, 2017
George Scott
Master
Level 3:
Master:
Answers
789
Questions
Helped
228688
Points
2507
Depends on you bose lifestyle model & tv could be a program isue..all that info is on line...this i know because i do a lot of bose
5 Related Answers
Anonymous
  • Posted on Dec 07, 2008
SOURCE: Bose Lifestyle V20 - no video out, no response to remote control
check the voltage setting on the power supply that connects the power cord to the media center. Mine was set to 230V. Changed it to 115V and the video starting working.
Anonymous
  • Posted on Apr 26, 2009
SOURCE: Bose Lifestyle 48 not responding to remote or manual functions
I hd this same problem a couple of months ago. Disconttect all peripherals (any exterior amps, roommates) plug the power connector and wait for two minutes, while waiting connect the main system. try turning the LS 48 on. If this clears thing turn off the LS 48 and connect the peripheral one at a time testing with each new connection. Happy hunting.
Anonymous
  • Posted on Jul 25, 2009
SOURCE: Home Audio Bose 48 - Remote not working
Had an issue with the Bose Remote RC38t1-27 not working at all. Changes batteries twice to no avail. Called Bose Tech support who walked me through the fix. I unplugged the power cord connected in the back of the system. Waited for 30 seconds or so and plugged it back into the system. Also made sure the power cord was uncoiled/unbundled as the RF (Radio Frequency) signal is within. Bingo!
Anonymous
  • Posted on Sep 07, 2009
SOURCE: Bose 3-2-1 Remote Control stopped working
I purchased a LAZBOY universal remote (at Fred Meyers, on sale for $9.99) and after a bunch of research and trial-&-error, was able
program it with a code (1629) which works reasonably well with the
Bose 3-2-1.
I don't have all the system-level functions (which I never utilized anyway) but do have all the basics as far as power, volume, source, and CD/DVD control.
Anonymous
  • Posted on Dec 15, 2009
SOURCE: My Bose 321 series II is not responding to the
Replace the batteries from the remote control. Press and hold the TV button on remote for 5 seconds. If the red light shines bright, your remote is OK since it is showing it's programmable side. If unit still won't go on using the remote, reboot the whole system by unplugging the power cord and other wire from the Subwoofer. Wait one minute, then replug all and see if the system displays BOSE 321 in front when re-connected. If so, try the remote and if that doesn't work, your dead, the Infra red communication device from the unit to the remote is busted inside the unit and needs to be returned to the company like mine!!!!!
I have bose cinamate home system i need codes to programe it to my spectrum remote
To program your Bose CineMate home theater system with the Spectrum remote, you will need to use the appropriate remote control codes. These rules vary depending on the model of your Spectrum remote and the specific model of Bose CineMate you have. Follow these detailed steps to program your Spectrum remote to control your Bose CineMate: Find the remote control code: First, you need to find the remote control code for your Bose CineMate system. Spectrum provides a list of remote control codes for devices on their website or in the remote control user manual. You can also try looking up specific codes online using the model number of your Spectrum remote and Bose CineMate. Turn on Bose CineMate: Ensure that your Bose CineMate system is turned on and in the proper mode for operation (e.g., TV or AUX mode). Enter programming mode: Press and hold the "Setup" button on your Spectrum remote until the LED indicator on the top of the remote turns on. Enter Code: Use the number buttons on the remote to enter the four-digit remote control code of your Bose CineMate. The LED indicator blinks to confirm the entered code. Test control: After entering the code, point the Spectrum remote at the Bose CineMate system and press various buttons (e.g., volume up/down, power) to see if it controls your Bose system. If it works, the program succeeds. Save the code: When the remote control works with your Bose CineMate, press the "Setup" button again to exit the programming mode. Now that the code is saved, your Spectrum remote should be able to control your Bose CineMate. Please note that not all remote control codes may work with all models of the Bose CineMate. If you can't find a working code, you can try the code search feature in your Spec
Remote codes for the bose solo
remote code for comcast xfinity x1 dvr. the codes that they had me try when i called did not work. Has anyone found any codes that actually work?
2helpful
5answers
I have the bose av28 media center, life style 28, remote broke, i have a time warner clikr 5 universal remote can this control the bose 28 ?
No, only the Bose remotes will work with it! Bose doesn't let any other remote to work on their systems.
2helpful
I have a Bose 321 GS III Cinema system. What code do I have to program in the Bose remote control to control my Motorola 1960 Cable tuner? The codes in the Bose manual do not work, so I expect that the...
having same problem with my bose 321 GSX. my mom just got shaw digital and likes the shaw remote better than the bose one. I can program the bose remote to do everything but can't seem to do it for the shaw remote. I think i need a code for bose as a reciever? I dunno... any help would be good eh!
2answers
Bose av28 access menu using control buttons
when this happened to me,,,I found out it meant that the video decoding ASIC was out....I could not get any DVD's to play to the TV, and finally, the "settings" menu would not go on the television screen....this means you need to have the mainboard replaced, and after twice doing this,,,,the Tech on the phone told me that the Video Decoding ASIC is very susceptible to power spikes,,,so I put a big APC filter in front of it....
2helpful
Bose Remote not linking to Samsung HDTV
I got my bose remote to work when I did a system update on the remote. Turn the TV on. Select the TV video input that connects the system. On the control console, press and hold setup until the system information screen displays. line 5 will display the currently installed console software version. on the remote press any button. Line 10 will display the currently installed remote software version. Do a bose system update. On the control console press setup. on the remote control, press the down arrow until update is highlighted and press ok. make sure yes is highlighed and press ok. on the control console plug a clean usb drive into the usb port.when prompted, remove the usb drive and connect it to a computer. open the drive and double click on the download_launcher file, which should bring you to an update page on bose.com. Once complete, put it back in the control console. When the update is complete remove the usb.
1helpful
Need v30 bose code for remote
Bose V 30 works on Radio frequency ............. so you need to have a unversal radio frequency remote conrol..... no IR (infrared) remote can control a bose lifestyle product..
why not use your bose radio frequency remote( the v 30 remote) to control the dvr plyer from motorola.. you can used the remote even to control your tv and other deices ..
all codes for your other systems are available in th e system settings option under remote control category to set up your system to control other devices
6helpful
3answers
Bose cinemate will not power on. light stays red?
Make sure your system is not plugged into a surge protector. Sometimes a surge protector will foul the system up, don't know why. lol. I fought with my system for 3 hours trying to get it to work, then moved it from my surge protector to the wall and it came on. If that doesn't work, try disconnecting the receiver module itself, wait 60 sec, then plug it back in. If that still does not solve the problem, I would suggest calling Bose Customer Service..
Code to control my Viewsat9000HD on Bose remote not working at all
Have you tried changing the codes in the system setting?
11helpful
9answers
My bose 321 system remote control sometime works and sometime doesn't.
When we try to use the remote the red light glows which I never saw glowing when it was working properly.What could be the problem?
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
