Hoover H120M Front Load Washer / Dryer Logo
Question about Hoover H120M Front Load Washer / Dryer
I have a Hoover Express Six 1200 with a broken door hinge can you supply me one please
1 Related Answer
Anonymous
  • 1294 Answers
SOURCE: manual
Click on Hoover (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Posted on Oct 05, 2007
I have a bosch classixx 1200 and hing has broken , will i need a whole door , or just hing , and where can get one for my husband to fit
Just a hinge ;-0)
Sorry, this FixYa Washer Forum does not supply service centre numbers, engineers, spares or spares sources, software, installation instructions or prices; it is just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will either have to search in your local telephone directories OR stay on line and search for '(make) washer spares' and hope that you can find someone/somewhere reasonably local.
Sorry again ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
4helpful
How do you repace the door hing on a AAA140 Hoover
should not need to as the 2 screws holding the hinge to the frontplate of the machine goes into a threaded nut welded to the panel (a torx 30 or 40 bit is needed).. just remove the screws and raise the hinge and pull forward..(keyhole slotted on)... then reverse to attach the new door...
1helpful
The machine door is hanging off the hinges xx do i need a new door or hinges
More than likely, all you need to do is replace the door hinge., you will probably have to seperate the inner door panel from the outer panel to fit new hinge.
Please rate my solution.
Thanks.
Broken door hinge replacement on Hotpoint Ultima
Remove all the screws securing the 2 door halves together, and gently prize apart the two halves with a screwdriver or similar, be careful not to drop the door glass.. You will probably be better off removing the door from the front of the m/c altogether.
Replace broken parts as req'd.
Plz rate my solution
Thanks.
Manual
Top Hoover Washing Machines Experts
Steve F
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
