Sanyo DS31590 31" TV Logo
A
Anonymous Posted on Sep 25, 2013
I have a sanyo ds31590 with the chassis #31590-01 which has a horizontal line when you turn it on and no sound.
4 Related Answers
salt56
TV Doctor
  • 373 Answers
  • Posted on Dec 30, 2007
SOURCE: Sanyo DS31590 31" TV vertical deflection
If the vertical is not defective or shorted there is a possiblity of bad solder connections on the vertical ic. If connections are good and has b+ voltage to the chip replace chip which is IC 501 LA7841 or LA7845 and change c511 (decimal point 1 film capacitor)
Anonymous
  • 5138 Answers
  • Posted on Dec 01, 2008
SOURCE: Sanyo DS31590 31'' TV DO I NEED CONVERTER BOX?
If you do not have cable or satellite YES you will need converter box anyone and everyone that uses antenna to watch tv needs converter Box.
Anonymous
  • 105 Answers
  • Posted on Jul 01, 2009
SOURCE: my sanyo ds31590 31 has a black picture with a thin white line in
check the voltage at vertical ic must get 24volt dc then replace the IC that all
The witch
Francisco Mauricio G
  • 1551 Answers
  • Posted on Jul 27, 2010
SOURCE: picture will suddenly get horizontal lines then
Maybe you´ve cracked solder joints on the vertical Ic and need to resolder it
Video and audio issue on my Sanyo DS31590 T.V.
line left to right is vertical circuit problem and may be linked to audio problem if both are fed voltage from a common source---Not a do it yourself repair unless have experience with this kind of equipment.
1helpful
I HAVE A SANYO MODEL 31590 NO PICTURE SOUND JUST A LINE IN THE CENTER
hi..hope this help you....a horizontal line in the center is an indication of defective vertical IC...its looks like a tab w/ 10-12 pins and has heatsink...your TV would works out fine when you replace the IC....but its better if let a technician replace this....pls. don't forget to rate and vote....thanks...
2answers
My SANYO TV24'' when powered on,only a bright horizontal light appeared after 3sec dissapered,no sound,no more picture.
your tv has suffered horizontal collapse this is not a cheap repair it contains most major parts of the power section
hope this helps
My sanyo ds31590 31 has a black picture with a thin white line in
2helpful
Line across picture tube
Had the same problem with mine. The vertical hold chip broke loose from the solder,Resoldered it works fine. You will need a magnifying glass to see this on the bottom of the board.
1helpful
2answers
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
1helpful
Line on t.v. no picture
If you are getting a horizontal line across the screen, It means the vertical amplifier IC is defective.
1helpful
1helpful
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
