SOURCE: Will the Jenn-Air JFI2089ATS accept 3/4" thick raised panels?
Hi: Raised panels, beveled are used all the time. Just check clearance of the thicker doors. Walls etc. Hope this helps, Jeff
SOURCE: I know this seems like a minor problem, but the
Welcome to FixYa.
The fact of the matter of the doors being at different heights is typically an indication the unit isn't level and can be simply corrected by way of screwing the legs/wheels up or down.
If you remove the grill below the doors you should see the wheels and the adjustment screws/bolts. #2 is the wheel, # 3 & 5 are the adjustment screws to raise or lower the unit.
i.e.
They are typically a 5/16" or 3/8" hex head/slotted combination. Try adjusting one or the other with small adjustments until you notice the two doors starting to level to each other.
Let me know how you manage and I'll try to help you in any manner i can going forward. Good luck.
Thank you for choosing FixYa today.
Regards,
Macmarkus :)
