did you have alternator and battery tested Disconnect the battery ground cable.
Remove the generator drive belt.
Release the tension on the drive belt.
Remove the drive belt from the generator pulley.
Disconnect the HO2 sensor harness clip from the generator bracket.
Position the generator bracket aside.
Remove the A/C line bracket bolt.
Remove the
power steering pressure line bracket bolts.
Remove the generator bracket bolts.
Remove the generator bolts and position the generator aside.
Remove the generator.
Disconnect the two generator electrical
connectors.
Remove the battery positive nut and washer.
Disconnect the battery positive cable and remove the generator.
Installation
NOTE:
When the battery is disconnected and reconnected, some abnormal drive
symptoms may occur while the vehicle relearns its adaptive strategy. The
vehicle may need to be driven 16 km (10 mi) or more to relearn the
strategy.
To
install, reverse the removal procedure.
