Question about GE 25GT511 25" TV
How do I hook up a VCR to my GE 25GT511 TV? - GE 25GT511 25" TV
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 337 Answers
SOURCE: GE Model #25GT511 Power on, no picture or sound
The question I have is if the tv stays on but with no pix or sound,we have a way to check,if you place your forearm in the face of the picture tube and the hair in your arm stands up it means you have the high voltage needed to light up the tube but something else is missing like the screen voltage or it has a loose conection in the crt board,if the hair in your arm does not react to static then we are missing the high voltage and the problem might be more involved and related to the horizontal circuit not creating the high voltage needed.If you are familiar with tv service you have a few places to check but if you are not to familiar play it safe and call for assistance from a professional servicer.Let Us know how it goes please.
Posted on Oct 26, 2006
Michael Borelli
  • 979 Answers
SOURCE: How to hook up VCR
Without line out connections on the DVD/VCR unit and line in or RF modulator for the back of the TV in question, that cannot be done...accordianman
Posted on Feb 09, 2008
gtaplytmpt
Andy
  • 90 Answers
SOURCE: Can't get my VCR to work
FIRST!!! Make sure you have the coax or AV cables plugged into jacks marked out on the machine.....then....
*If you have it hooked up with a Coax cable, you should immediately have picture and sound when you turn it on. Make sure you have a dvd/vhs running and switch between channel 3 and 4. if this doesn't work, make sure that you have the cable connected to the one marked 'in' or 'cable in' or 'ant in'. then retry the previous steps.
*If you have it hooked up through A/V cables (Red/Yellow/White), make sure you have them all connected to the same set of jacks. They should be labeled Aux 1 or something similar and are generally surrounded by a box molded into the TV's plastic casing. You will then have to use the TV remote to switch TV/Video settings until you get to the one that matches the Aux jacks you have it plugged into. Again...make sure a dvd or vhs is running and keep flipping until you find a picture.
Hope this helps!!!
Posted on Dec 29, 2008
How Can you record tv show using a converter box
Hook the converter box cables to the input RCA jacks on the back of the VCR, then hook the output RCA jacks to the input RCA jacks to the TV, Keep the VCR on channel 3 or 4, on the TV in menu scroll through the source settings to find the what source the vcr is using
May 05, 2014 | GE Vg4261 Vhs Tape Vcr Plus 4 Head Hq...
Lost Manual. "Clock set, year, month, etc." on screen. Working with "Menu" button doesn't fix it. How do I get it off?
There is usually a cancel button.
If that does not work, try unplugging the TV power cable for two minutes.
If still no luck , then give me the complete model number, or enter the model number here to access manual.
Regards.
Nov 18, 2009 | GE 25GT511 25" TV
Sleep timer
It does, through the menu function
Jun 11, 2008 | GE 25GT511 25" TV
GE 25GT511
Look for where to turn off subtitling. It'll be there somewhere, accessible via the remote.
Mar 26, 2008 | GE 25GT511 25" TV
How to hook up VCR
Feb 09, 2008 | GE 19GT243 19" TV
VG4043
Typical belt drive problems. Have a belt job performed on the unit
Sep 27, 2007 | GE VG4040 VCR
Taping a show
as it is not seen from outside & can not be seen so it is not there. no there no hidden compartments now what you can do for recording is you can connect separate adaptor from market it can be connected from out side.
Sep 25, 2007 | GE 25GT511 25" TV
Oct 25, 2006 | GE 25GT511 25" TV
TV doesn't receive higher channels
Depending on the chassis, it could be the OBT has a bad componet or a parts bad in it or if theres a standup tuner it has to be replaced. You should take the set into a repair place for an estimate good Luck
Jul 28, 2006 | GE 25GT511 25" TV
Blurry screen GE 25GT511
hi There shouldnt be much in the focus system to go wrong as really there is nly the tube base and the flyback transformer. The usual for a TV is the tube faulty so its beyond repair. You could try the focus control, this will be on the flyback transformer. Back off TV, look for a heavy lead going to the dome of the tube at centre top and with eyes ONLY follow that back to the flyback transformer. On the side of that transformer is 2 screws, one near the top is the focus control. You will need a screwdriver to turn it and it usually has a seal to be broken. That will turn from say 8 o clock to 4 o clock no more, turn it up clockwise, try both ways. if it almost fixes but not quite it would be the tube. good luck
Mar 21, 2006 | GE 25GT511 25" TV
Televison & Video Logo
29 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
