This is for a woman's watch but may apply to yours. You need to remove the screws around the bezel of the front of the watch (not accessed through the rear like most watches).
Be sure to use the correct size screwdriver to avoid marring the screws. Then you will need to remove the half of the split stem attached to the crown. Remove the movement from the front, replace the cell, lube the gaskets, and reassemble.
You do not need to go to US for watch repair. Follow this link:
http://www.ebel.com/#/en/ On the right bottom side of the screen click on store locator. Now click on Middle East and Africa, then click on Israel. Choose the city (or nearest to you). Use the phone or email address to get in touch and clarify with EBEL your problem. Rate me, please.
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
Thank you for contacting FixYa.<br />
I would recommend you send your watch here:<br />
<a href="http://precisionwatchrepair.com/ebel/index.html">http://precisionwatchrepair.com/ebel/index.html</a><br />
Best regards.<br />
Jewel
to change the batt on an ebel womans watch i simple. 1 take out screws from bezel. 2 lift off , make sure to keep rubber gasket in place. 3 pull out stem to the set position. 4 be very carefull not to bend / touch hands. 5 turn case upside down, and you will see the opp side from the winder drop out slitely. with your fingernail pull downwards gently on works, then when you have it out a little on that side, turn it back over. and continue to lifft up gently, 5 as you do so, start to rowtate the works counter clockwise. the stem is made to .bend / swivel and the works will turn upside down and lay back into the case. to protect the face while installing the batt. 6 when done gently lift the same way but rowtate clockwise. but make sure you grab sides of works and not the face. ( the hands are very delicate) 7 take the batt to a jeweler to replace you will never find a batt with the same number ( ebel made sure of that ) they want you to pay 140.00 to 240.00 for them to do it. but a jeweler can match it. now that said, once you take the bezel off, your ebel warenty is void. so 140 -240 or $5.00 your choice i have had meny watches over the years all with rubber gaskets and have replaced batts is some five times and the gasket are still fine. and a batt will last 3 to four years. five in 15 years could cost you $ 1020.00 in the long run. hope that answers your question.
i have changed the battery on my and my wifes ebel classic wave watch,,
step 1 ...remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
step 2 ...remove all 5 gold bezel screws
step 3... be careful,, the bezel/crystal will pry off easy
step 4... be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
step 5.. small screwdriver and remove/replace battery
step 6... reinstall watch guts/bezel and gold screws
step 7... push crown back into watch
step 8... take wife and kids to dinner ,,you just saved three hunderd bucks
if have done it many times ,, you can do it !!!!
