I can't change the bottom drawer setting. It's stuck on "delicate". I want it back to "normal". I don't care if I can only move it back to normal and leave it there. This drawer was always tricky. Had to make sure the lights and "button" were in a shadow to get them to advance. I can't get them to advance at all. The Eco button still responds and switches on and off.
Hi Lenesse,
Unplug the unit for 30 Minutes, put the dishwasher on OFF and plug it back in. Restart the Dishwasher (new cycle) It is possible to see an Error Code.Let me know what happen so I may give you further instructions I have also attached a link to the Operating manual.
Good Luck,
JP https://www.manualslib.com/manual/51833/Fisher-And-Paykel-Dishdrawer-Dd605.html
F1 (or E1) is a "Flood" fault and means there is water in the bottom pan. This is beneath the bottom drawer. The sensor is in the left, rear corner of the base pan. Any kind of leak, including over sudsing or split hoses or or lid not down fully due to tall items in tub, can cause this. Remove the lower drawer, dry the water from the pan bottom, reinstall the lower drawer and check operation. If this error recurs you must find the leak and correct it.
you will need to replace both draws control boards, with the dd603 control boards they have a small touch button panel on the top of the board which they didn't put a protective layer or plastic over and basically what happens is steam gets on the copper tracking and corrodes it hence the fact it doesn't work anymore, all new control boards even the replacement for yours comes with a plastic strip over the board. hope this helped
its quite simple there are 2 plastic tabs on either side of the draw on the bottom front corner behind the metal panel on the plastic tub part, simply push on the tab and slide the whole rail back (the plastic tab is the end of the rail it sits on) on both side and the draw will lift out (note it doesn't come out very far as the hoses and wiring will still be attached but will still allow you to access everything). message me if you need pics or more help
