You must online complaint here - Gmail Is Up or Down
You need to check out all these:
1.
Check for Conflicting Software:
Some third-party software can
cause Google Chrome to crash. When this happens, you'll see the message "Whoa!
Google Chrome has crashed. It's possible that you have malware that can
Google Chrome has a hidden page
that will tell you if any software on your system is known to conflict with
Google Chrome. To access it, type chrome://conflicts into Chrome's address bar
and press Enter.
You can try to fix these
crashes by updating, disabling, or uninstalling any conflicting third-party
software listed in "about:conflicts" on your computer. Also, take a
look at Google Chrome's known issues for specific solutions to resolve crashes
caused by some software.
2.
Scan for Malware
This includes malware and
network-related software that interferes with Google Chrome. Malware can also
interfere with Google Chrome and cause it to crash.
You can try using Malwarebytes,
or other anti-virus software to scan for and remove malware or you can also try
searching the web for information related to any conflicting modules listed on
the chrome://conflicts page (Windows only), to see if there are other steps you
can take to remove malware.
Many crashes are caused by
malware. If you're experiencing frequent crashes, try scanning your computer
with antivirus software.
3.
Solve Flash Crashes
We have found that the Flash
plugin Chrome includes can cause it to crash in some cases. If you are seeing
regular Shockwave Flash crashes, you may want to try disabling the internal
Flash plugin and using the standard Flash plugin in Google Chrome.
4.
Switch to a New Profile
Chrome crashes may be caused by
a corrupted profile. You can test this by creating a new profile from Chrome's
Settings screen. Open the Settings page from Chrome's menu and click Add new
user under Users.
Change to the new profile after
creating it and see if the crashes continue to occur. You can sign into Chrome
with your Google account to sync the data from your old profile. However,
Google recommends you don't copy any files from the old profile folder by hand
- they may be corrupted and causing the problem.
5. Fix System File Problems
Google recommends running the
SFC.EXE /SCANNOW program to check for - and fix - problems with protected
system files on your Windows system if you are encountering crashes. To do
this, locate the Command Prompt in your Start menu (press the Windows key and
type Command Prompt), right-click it, and select Run as Administrator.
Type the following command in
the Command Prompt window and press Enter:
SFC.EXE /SCANNOW
Windows will scan your computer
for problems with system files and fix any problems it finds.
6. Hardware
issues
It can also cause Chrome
crashes. You may want to test your computer's RAM and ensure it isn't faulty.
If still problem not solve,
maybe you should try these simple steps:
1. Try
restarting your computer first. It could be that the computer has just
encountered a slight glitch on your system, which is causing things to not work
properly.
2. Remove
and Re-install the Google Chrome application. Doing this will allow your
computer to read the files a lot better and faster, and also repair any damaged
or corrupt files that have been causing the issue. To remove the Google Chrome
application, first insure that you have another browser, such as IE or Firefox,
click "Start, Control Panel, Add / Remove Programs," locate
"Google Chrome" click UNINSTALL next to it. When the application
loads, select "REMOVE" (not repair). Follow the uninstall process,
and restart your PC. Problems uninstalling or re-installing Chrome indicate
mal- or spy-ware, which must be dealt with.
3. Remove
any extensions that you have on Google Chrome. Although they are a great
way to personalize your Internet browsing experience, they are not so good for
speed and functionality, as many can cause the application to crash. To remove
any extensions follow these steps: Open up Google Chrome. In the address bar
type chrome: //extensions. Click Uninstall, or Click Disable if you think you
may use the add-on in the future. Restart your browser.
4. Disable
plug-ins. Chrome can get bogged down with plugins that you aren't using,
also. Type about: plugins into Chrome; it will redirect to chrome://plugins.
Disable any that you aren't currently using.
Hopefully your Google Chrome crash problems are
gone. Hope it works. Sharing is always caring.
On the off chance that you are routinely observing the "Hold up! Google Chrome has slammed" message, there is likely an issue on your framework. An incidental accident can occur, however, customary accidents are presumably brought about by something you can fix.
On the off chance that you are interested exactly how frequently Chrome is smashing, you can type chrome://collides with your area bar and press Enter to see a rundown of accidents and when they happened. This is only one of Chrome's many shrouded chrome://pages.
Expansions and Add-ons
These things are exceptionally valuable however Chrome regularly gets shaky because of various program expansions, modules, or additional items. In spite of the fact that it is anything but an extremely fulfilling arrangement, keeping just 2-3 additional items in the Chrome program can enormously lessen the recurrence of Chrome crashes. Have a go at decreasing the number of augmentations and additional items you are as of now utilizing and you will see the change.
Incapacitate the clashing modules in Chrome
Presently we are discussing a Module which is a key segment of any application. It contains a string of programming techniques that are fundamental for the run-time of uses. On the off chance that these modules are causing issues, at that point you get Chrome crashes accordingly. To recognize these issues, type chrome://clashes in the 'Address Bar'. The program will at that point load all the modules and furthermore distinguish the defective ones, permitting you to incapacitate them. It will likewise make reference to the hazardous application or augmentation alongside the modules.
Accordingly, it is ideal to uninstall or expel such clashes from your framework by utilizing 'Include or Remove Program' work in 'Charge Panel'. Like it, you can uninstall the clashing expansions from Google Chrome.
Fix the Chrome client profile information
Numerous reasons cause Google Chrome's client profile information to get defiled. Chrome should be shut before closing down Windows since it needs to spare the information in the client profile. On the off chance that Chrome can't refresh client profile because of an unforeseen shutdown, at that point it can harm or degenerate the unsaved information which at last causes an issue. To fix this issue, open 'Document Explorer' and check 'Concealed things' under the 'View' tab. Close Chrome on the off chance that it is open and, at that point get to the Chrome client profile envelope by following this registry:
C:\Users\youraccount\AppData\Local\Google\Chrome\User Data (your account speaks to the name of your Microsoft account)
Right-snap to 'Rename' the organizer 'Default' to anything like Default_1, Default_bkup, and so forth. That is truly it. Test it by re-opening your program.
Impair the Sandbox security briefly
Chrome runs a security instrument considered Sandbox that ensures the rendering of HTML and JavaScript from vindictive projects. It creates a controlled and limited condition around Chrome to ensure your working framework for getting harmed. Handicapping the Sandbox highlight has worked for certain individuals however it isn't suggested by most. Right-click the Chrome symbol and open the 'Properties' to make changes. Under the Shortcut tab, you will see a way composed in a 'Target' box. Press space toward the finish of the content, simply include - no-sandbox and snap OK.
Clear history, treats, and other perusing information
A generally normal and simple arrangement is much of the time cleaning the perusing information put away in Chrome. Open the Chrome menu by tapping the cheeseburger button or the three-lines symbol on the upper right of the program and open 'Settings'. At the base of the Settings page click 'Show propelled settings' and under Privacy heading click 'Content Settings' first. At that point, under Cookies heading, select the alternative that says 'Keep neighborhood information just until you quit your program' and snap OK. This permits Chrome to consequently clear the treats.
Also, click 'Clear Browsing Data' which is directly adjacent to 'Content Settings' and select all choices with the exception of 'Passwords'. This permits you to stay marked in your sites or internet based life accounts.
Source: Google Chrome Keeps Crashing
This is the path in Win 7 to fix this.
log in under your profile.
Click Start
Go to C:\Program Files\Google\Chrome\Application\39.0.2171.95\Installer
Take this path and click the installer. (Your version of Chrome may be different as time passes and newer versions are updated and installed. Look for the newest date in the file since you cant check your version because youre crashed.) After youve clicked it, be patient and notice that your icons on your desktop will flash. It's reinstalling your current version of Chrome.
This is how I fix it in the school district I work in. All of our Chrome installs are done with the .msi Chrome package.
I would assume that this will work with the web installer most folks use.
Please let me know if there are issues with this.
Either your wifi or to many systems running at once
SOURCE: google chrome the application failed to initialize properly ( 0X0
Read the below document by Google :-
http://service1.symantec.com/SUPPORT/ent-security.nsf/docid/2008090310121448
One more option, that might work - Reinstall Google Chrome.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: google chrome crashes
Right Click at Google Chrome at your Desktop , Choose Properties.
Go To Shortcut Tab,
Go To Target
And add this at the end " -no-sandbox"
(there is a space at the front)
SOURCE: My Google Chrome crashes when
Uninstall google chrome and do this Repair Active-X, Flash and Other Registry Error using registry cleaner reginout check Flash Player Compatibility Updating the Sound Drivers now install google chrome , it will solve the problem
