SOURCE: Error 0495 - Receiving Faxes
Might be a problem with speed of the fax. See related question.
SOURCE: Our Epson Sylus CX9400Fax Series is not receiving
Ok, here's a check list for you.
SENDING
Check the following:
Follow these steps to turn off the ECM setting:
RECEIVING
Try the following if you can't receive a fax:
SOURCE: Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
SOURCE: epson rx680
one ink cartridge is out of ink but...
when we try to replace one of the color ink cartridges we get this error message:
ink cartridges cannot be recognized. make sure ink cartridges are installed correctly - how do I get the printer to recognize my full ink cartridge?
SOURCE: epson fax hooked to magic jack communication error
I had same problem when I used the dual jack. I had to change it. I had the dual jack which would make it easier to use when I was going to send a fax.
Good Luck
Usually, faxes are
temporarily sent to the printer's memory when one of the cartridges' ink level
is not substantial for printing. You are advised to replace the cartridge/s, *without
navigating away from the message "fax sent to memory", by opening
the printer cover and replacing the low-ink cartridge/s. After the new
cartridge/s is installed, close the printer cover and press OK button to let
printer print the fax stored in the memory.
* Make sure not to navigate away from the "fax sent to memory" message. You will lose the fax-in-memory data once you turn off the printer or navigate away from the message.
