Mintek MDP-1070 Logo
A
Anonymous Posted on Sep 24, 2013
Not showing pictures
Why wont my sabrent usb floppy disk drive show pictures
If you are saying that you can see the files but it does not show the pictures. Check the file association for that pictures file extension. All that it might take to make it see the picture is to associate the file extension to a picture viewer program.
7helpful
Card locked shows of view finder, cannot take a picture it shows a't picture but won't take a picture
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
I have a d80.problem: lcd will not show anything. lcd will show previous taken pictures
Which is it? The LCD will not show anything, or it will show previously taken pictures? Does it show menus when you press the MENU button?
The D80's LCD will not show pictures before you take them. The LCD is for menus, shooting information, and reviewing pictures already taken. You must use the viewfinder for composing your pictures. The LiveView capability which lets you use the LCD for composing is a recent development in DSLRs. Nikon introduced it to their product line with the D3 and D300, released years after the D80.
2answers
How do you set the background on a Dell to show a slideshow of all of the pictures?
To use your own pictures
1.
Find the pictures that you want to include in your slide show. All of the pictures must be located in the same folder.
Open Desktop Background by clicking the Start button Picture of the Start button and clicking Control Panel. In the search box, type desktop background, and then click Change desktop background.
2.
If the pictures that you want to use aren't in the list of desktop background pictures, click the Picture location list to view other categories, or click Browse to search your computer for the folder where the pictures are located.
Picture of the Picture location menuLook for pictures in other locations on your computer.
3.
Select the check box for each picture that you want to include in your slide show.
By default, all of the pictures in a folder are selected and will be part of the slide show. If you don't want all of the pictures in the folder to be included, do one of the following:
Clear the check box for each picture that you want to remove from the slide show.
Picture of one check box cleared in a group of selected photosClear the check box to remove a picture from the slide show.
Press the Ctrl key, and then click each picture that you want to remove. Only the selected pictures will appear in the slide show.
To create a slide show of pictures on the desktop, you must select more than one picture. If only one picture is selected, the slide show ends and the selected picture becomes the desktop background.
If all of the pictures in the folder are selected, any new pictures that you add to the folder will be added to the slide show automatically.
4.
Do one or more of the following:
Click an item in the Picture position list to crop the pictures to fill the screen, fit the pictures to the screen, stretch the pictures to fit the screen, tile the pictures, or center the pictures on the screen.
Click an item in the Change picture every list to choose how quickly the slide show changes pictures.
Select the Shuffle check box to have the pictures appear in a random order.
5.
Click Save changes.
To use pictures that Windows provides as part of a theme
1.
Open Personalization by clicking the Start button Picture of the Start button, and then clicking Control Panel. In the search box, type personalization, and then click Personalization.
2.
Under Aero Themes, click a theme to apply it to the desktop. With the exception of the Windows 7 theme, all of the Aero themes include a desktop background slide show.
3.
To change the theme's default slide show pictures or settings, click Desktop Background.
4.
By default, all of the pictures associated with a theme are selected and will be part of the slide show. To add pictures from other themes to your slide show, do one of the following:
Point to each picture that you want to add to the slide show, and then select its check box.
Picture of one check box cleared in a group of selected photosPoint to a picture, and then select its check box to add it to the slide show.
Press and hold the Ctrl key, and then click each of the pictures that you want to add. Only the selected pictures will appear in the slide show.
5.
To change the slide show's settings, do one or more of the following:
6.
Click Save changes.
Your slide show will be part of the unsaved theme that appears under My Themes.
For information about customizing and saving themes, see Create a theme.
You can find more themes to add to your collection in the Personalization Gallery on the Windows website.
For information about customizing a desktop background slide show, see Make changes to your desktop background slide show.
If i put my camra on self timer win i print the pictures will the time show up on the pictures
The time it took the picture? You want to know if the camera will show the time it took the picture using the self timer?
My answer is Yes and No.
Do you have your camera set to showing the date and time on the pictures now? If you do, then using the self timer would not change anything.
If you do have it set to showing on the picture and you don't want the date and time to show then change the setting on the menu function of the camera and turn this option off.
If you do not already have the camera set to show the date and time, using the self timer option is not going to make it suddenly appear.
Hw to make my own slide show
YOU MUST GET PICTURES AND PLACE THEM IN THE CREATE A SLIDE SHOW AREA. ONCE YOU HAVE SEVERAL OF THEM HIT CREATE SLIDE SHOW. YOU CAN COPY AND PASTE PICTURES FROM YOUR COMPUTER.
4helpful
2answers
Can't find hidden media folders
Follow these steps to hide or show pictures on the BlackBerry smartphone:
  1. On the Home screen of the BlackBerry smartphone, click Media.
  2. Go to Pictures.
  3. Open the picture that you want to hide.
  4. Press the Menu key and click Properties.
  5. Select the Hidden check box and click Close.
Follow these steps to show a picture on the BlackBerry smartphone:
  1. Click Media.
  2. Press the Menu key and click Explore.
If the picture is in Device Memory,
  1. Click Device Memory.
  2. Press the Menu key and click Show Hidden.
If the picture is in Media Card,
  1. Click Media Card.
  2. Click BlackBerry.
  3. Press the Menu key and click Show hidden.
Additional Information If the computer is set to Show all hidden files and folders, the BlackBerry smartphone user should be able to view all hidden pictures by using Roxio® Media Manager. However, pictures cannot be hidden or shown using Roxio Media Manager. If a picture is on a media card and the computer is set to Show all files and folders, pictures can be viewed, hidden and shown by using the removable disk drive.
The slide show will not show all the pictures on my memory card.
There should be no limits. However, please install the latest firmware on your frame and get it from www.kodak.com/go/downloads . Also, try a smaller memory card size and check if it has something to do with the card.
Kodak easyshare 5300 not showing ALL pictures on my memory card
maybe the resolution of other pictures is more thyan the printer reader supports
check uninstall and install printer and try again
also make sure that the 4 readable photos Format is like the other pics
plz rate!
1helpful
Top Mintek Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
