Optimus Sta-3750 Sta-3760 Stereo Receiver Remote Control Cat 31-3047, 31-3048 Logo
Question about Optimus Sta-3750 Sta-3760 Stereo Receiver Remote Control Cat 31-3047, 31-3048
Optimus sta 3760 receiver standby light on will not respond to turn on
Dwayne Kitt
    New Friend:
Looking for a replacement remote control?
Posted on May 23, 2017
3 Related Answers
John Weinreich
  • 336 Answers
SOURCE: Optimus STAV-3260 Digital Synthesized A/V Surround
Could be several causes. Bad connection near the stand-by power transformer or the transformer itself could be open. The main Micro could be bad. This is a job best left to a servicer. Optimus was sold only by Radio Shack, they still do repairs.
Posted on Feb 03, 2010
Testimonial: "thank you.you answered my question"
Anonymous
  • 4234 Answers
SOURCE: How do I reset the protection mode on my Optimus
You can not "reset" protection mode. This is an indication of a defect. Disconnect the speaker wires completely and if the protection mode remains, then the problem is internal to the unit and is likely to be shorted output transistors. Expect a parts cost in the $20-$50 range for this repair.
Dan
Posted on Mar 26, 2010
Testimonial: "Thanks"
Anonymous
SOURCE: I have a Optimus STA-3750 am/fm stereo receiver
I have the same receiver, but have been unable to program it with my Universal Code. I do not have the original remote. Did you find a code that controlled it? I found one website that had the owners manual online, maybe that would help: http://support.radioshack.com/support_audio/doc58/58124.htm
Posted on May 20, 2010
Optimus STA-3500, display is so dim you can't read it without a magnifying glass. No "dimmer" adjustment visible unless there is a special code........?
The manual might have the code to adjust the display screen optimus sta-3500 manual on google and on the companies official website too.Or call or email customer service then.
How do i get my optimus sta-3180 receiver out of stuck in standby mode
I found the plastic button plunger on the front becomes too short to actuate the tiny on/off switch inside. Remove the cover and insert a piece or two of thickish paper (like file-folder thickness) between the plastic plunger and the switch. Let it hang back over the circuit board so it will stay in place.
My Optimus STA 3760 Receiver will not play any sound on tape monitor, and will only play the right channel on the phono setting. What could be wrong with it/ how do I fix it?
Chemically clean all of your input selector switches and see what happens. If still have issue then one of your amps is in need of repair.
I have an RCA STA 3900 stereo reciever that wont turn on. Standby light is on. Tried resetting it from the back but didnt work. Please advise
A standby condition can mean a fault in the receiver. voltages in the system are off. This can either be a bad diode or power transistor.
Optimus stereo receiver universal remote codes
go to link below and click the green "Notify Me" button when this item is stocked. We will inform you when we put one in stock. You must purchase a new OEM remote, universals will not work. OPTIMUS STA3750 3760 Remote Control
Optimus sta 795 manual
I need service manual for STA-795
RCA STA-3900 standby light on will not turn on
POWER SUPPLY BLOWN FUSE CAUSED FOR A BLOWN OUTPUT TRANSISTOR , DO YOU HAVE THE NUMBER OF THOSE TRANSISTORS??
Top Optimus Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
NOEL
NOEL
Are you an Optimus Audio Player and Recorder Expert? Answer questions, earn points and help others
