Question about Konica Minolta bizhub Office Equipment & Supplies
Shows a lot of lines on the paper when I copy ? what is solution of this problem?
Posted by tech14 on
steven brickhouse
  • 19 Answers
More info please
Posted on Oct 19, 2013
Why do my copies have black lines down the paper?
if its just copies clean the small glass to the left of the large glass its called the slit glass and is usally about 12 inches long and 2 inches wide if it comes out on prints as well as copies its a drum or fuser check to see which is bad another way to test if its the slit glass make a copie from the large glass if no line its definatly the sit glass
May 27, 2014 | Kyocera Epson Workforce Pro Wp-4530 Wp4530...
[email protected] have a 5250 kodak printer and when I copy something the paper comes out gray with black lines down the side. It does print. Why is the paper colored and have lines on it?
You are possible loading the paper in up-side-down. Try loading the paper flipped over. A lot of kodak photo paper have bar-codes printed on one side for the printer to scan and verify you are using the proper paper for the printing job you assigned to it.
Apr 08, 2011 | Cameras
3 thin black lines on copy
Do the black lines show up when you use the adf or if you make a copy from the copyboard glass. If the lines only show with the adf > there is a small **** of glass on the left side of the copy board glass > I would clean the slip glass with windex or a damp cloth..... Good Luck
Jun 08, 2010 | Canon imageRUNNER iR C2880 Color Copier
Extra line on copies
if you are feeding the paper through the document feeder... then the rectangular **** glass is dirty... clean it...
if you cleaned that and it still shows lines... do a drum refresh...
still lines... developer refresh...
if still lines then clean charger... still lines... replace charger...
still lines... replace drum
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 17, 2009 | Office Equipment & Supplies
Do I load the original for faxing right side up or upside down? HP officejet v40
Look at the input tray it shows a symbol of an original.
If the lines on the symbol face you , then put the paper in face UP.
If the lines are on the folded corner of the symbol, then place the paper in face DOWN.
If you are still not sure, place the paper in face UP and press "COPY"
If it copies the page, then that is the correct orientation.
If thre copy is blank, repeat the copy test with the document face DOWN.
Sep 28, 2009 | HP Office Equipment & Supplies
Want to copy images from notebook paper without blue lines apparent
yes, you are loking for border erase function. when you find it then look for what looks like two peices of paper side by side, you will then possible be allowed to adust the sixe of the erased area
Apr 24, 2009 | Xerox DocuColor 12 Color Copier
HP Officejet J5780 All-in-one Injet prints a grey line down the right side of the page when copying using the automatic document feeder. It does not show up when printing; and it does not show up when...
lift the feed area and look at the small glass plate where the auto feed paper is actually scanned. That needs a good cleaning. Since the paper runs across it even a tiny little obstruction such as paper left from a paper jam or a dot of ink from that pen you used to unstick that last paper jam (maybe its just me??). That one dot turns into a line when the paper rolls across it. Clean well and the line will dissappear.
Feb 27, 2009 | HP Officejet J5780 All-In-One InkJet...
Vertical lines on copies received
Run a copy of something through your machine. IF the lines show up on your copy, and also lines on your incoming faxes, then your drum cartridge is bad.
Replace the drum cartridge with a new one and you should be back in business.
If you have any other questions, please post again.
I hope I have helped you with your question.
Please remember to post a rating if I have helped you.
Have a good day.
Mac =)
Jun 04, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
2 parallel lines show up on the copies
try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of tha glass specialy the right side.
Apr 11, 2008 | Sharp AL 1631 Copier
Lines show on printed copies from Muratec MFX 2500
Probably a bad cleaning blade in the toner cartridge or a dirty charge wire.
Look for a small slider on top of the cartridge.
Dec 18, 2007 | Muratec MFX-2500 Plain Paper Laser Fax
22 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
