Question about Broderbund PrintMaster Gold 16 for PC
SOURCE: error message 1305
Microsoft has error 1305 as an "error reading from file." Check out http://support.microsoft.com/kb/248263 And try there troubleshooting, it could be that the disc is scratched or dirty, the drive could be bad, or it may be incomp[atable with the current operating system. The above link is your best first attempt at solving the problem.
good luck, hope this helps.
Posted on May 08, 2009
SOURCE: Just got Windows 7 and trying to install
Windows 7 has a compatibility wizard that you can use to help install it. Go to start, control panel, and then type in troubleshooter in the search box. Under programs, click "run programs for other versions of windows." Follow those instructions. If you need to browse to the setup file on the disc, do so. If that does not work, you can go to Broderbund's web site. They have a compatibility update for Gold 17 on their website. Unfortunately it is for Vista, but it still might help you with the compatibility issue
encore .
Posted on Nov 18, 2009
SOURCE: Print Master Gold 16 compatible with Windows 7?
Compatibility Wizard
1. Open the Program Compatibility Wizard by clicking the Start button , clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Posted on Jan 04, 2010
SOURCE: will Printmaster Platinum 16 run on windows 7 I
Printmaster Platinum 16 is not compatible with Vista or windows 7.
Posted on Oct 24, 2010
SOURCE: Can I load Printmaster 16 on Windows 7?
Printmaster 16 will work with Vista and Windows 7, you need to run setup.exe as administrator.
Posted on Dec 12, 2010
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
Apr 28, 2011 | Encore PrintMaster 17 Gold for PC
Mar 19, 2011 | Encore PrintMaster 17 Gold for PC
Feb 18, 2011 | Broderbund PrintMaster Platinum 16
Dec 07, 2010 | Broderbund PrintMaster Platinum 16
Oct 24, 2010 | Broderbund PrintMaster Platinum 16
Mar 28, 2010 | Broderbund PrintMaster Platinum 16
Feb 11, 2010 | Broderbund PrintMaster Gold 16 for PC
Oct 13, 2008 | Computers & Internet
96 people viewed this question
