Canon PIXMA iP1600 Printer Logo
Posted on Sep 19, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ink cartridge (not) installed properly
Whenever i try to print, an error message pops up saying that an ink cartridge is not installed properly. I've taken them out and put them back in numerous times, and nothing seems to be working. I know they are the right cartridges and that they are properly installed. But the printer refuses to print.
  • 5 more comments
  • Anonymous May 22, 2008
    The printer keeps telling me to install the color cartridge and wont print. I have installed the color cartridge and it still keeps blinking saying install color cartridge. It's an HP
  • help1234567 May 26, 2008
    cant fit cartridge
  • Gary ET Dec 22, 2008
    My HP does the same thing
  • ohri Dec 25, 2008
    i bought a canon ij ip 1600 printer
    i have refill my both cartridge.
    and when it is inserted on printer
    then printer display an error message cartridge not install proper
    plz give me solution of my problem
  • jeanoakpark Dec 25, 2008
    After refilling the same old cartridge, it doesn't print.
  • amang_cute Feb 14, 2009
    hi, i have experienced the same, just 2 days ago my printer is working,then suddently this day, it does not at all, and it prompt an error that the cartridge was not installed properly, i did the pulling and installing again the cartridge but none happen, i have unplug the power cord and usb for about 10mins for the said own printer resetting but when i opened it and installed a new driver, it was still the same error.. pls help.
  • Anonymous Mar 20, 2014
    since I changed cartridges, whenever I try to print a message saying printhead not installed comes up. I replaced the cartridges and pushed a little gray object (that appears to tighten the cartridges, they still don't print.
Anonymous
Level 2:
Scholar:
  • Expert 68 Answers
  • Posted on Sep 19, 2007
Anonymous
Expert
Level 2:
Scholar:
Answers
68
Questions
0
Helped
102053
Points
125
Did you make sure that the colored tape was removed from the back of the ink cartridges? The manufacture puts the tape on there to protect the circuits during shipping. If the tape is still there it would not be able to communicate with the printer or computer.
  • Anonymous Sep 23, 2007
    Since it is not the cartridge. Have you removed the drivers and software ? using add remove programs. Then download a registry repair program ( this will make sure any error entries in your registry are removed.) then install your software again. Follow manufactures detailed instructions to make sure you have a working printer. I am asuming that your printer connects through a USB port? Goto you device manager and see if the USB is working properly. Contact me back if you are still having problems. I will try to help you sort this out. TechWizard
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8412
Points
Got the same problem, i just want to ask whether i have to replace the cartridge already since, none of your instructions worked for me...hope you could help me out, i been thinking hard about it so bad
2 Related Answers
Anonymous
  • 832 Answers
  • Posted on Dec 16, 2007
SOURCE: Ink cartridge (not) installed properly
unplug machine from power outlet. take all carts out. wait 5 min. plug machine to power. wait until machine demands carts. reinsert carts and make sure they are secured. answer display when asked if you have changed.
If you still have the error message use a original brother cart.
Anonymous
  • 8 Answers
  • Posted on Sep 13, 2008
For the Canon iP1800 printer are you sure you're using the 30 for black and 31 for color?
And make sure they "click" when installed. That should confirm that they're nice and tight in their ink compartments.
Besides that, maybe reinstalling the printer drivers could do something?
How do i fix Epson Scanner Error code w-11?
Steps to troubleshoot Epson Printer error code W-11
Step 1: Replace the printer cartridge
The very first step is to replace the cartridge. If you see that this error code remains as usual even after a replacement has been properly placed inside the printer then, the most probably it signifies that the cartridge was inaccurately installed. To replace the cartridge, perform the following instructions:
§The very first thing is that the Epson printer and its software will let users know when an ink cartridge is in low or expended state.
§If it is found that the ink cartridge is expended then, an automatic message will appear on the printer's LCD screen asking users to replace
§It will further perform a proper printing process, copying as well as the scanning in a smooth way.
§Make sure that you have kept the ink cartridges out of the reach of children.
§Keep a note that you won't be able to copy, scan or print whenever an ink cartridge is expended even if the other cartridges are not expended. So, it is recommended for users to replace the expended cartridges before copying, scanning, or printing process.
§Keep a track when you are working with Windows system to check whether black ink is low or there is more color ink than black ink. A user will get an error message when to print from their computer device.
§The next thing what a user needs to do is simply to save black ink by using a mixture of colors. This message will only appear if a user has selected the "Plain Paper/Bright White Paper" optionas the paper type and the "Text' as the Quality Option setting.
If you need any further help kindly visit us: Epson printer error code w 11
Toll-Free No: +1-888-633-7151
Printer wont reconise ink cartrige
Make sure you've removed the protective tape from the cartridges that you inserted into the printer and that the cartridges were installed properly. Are you getting an error message or is the printer just not printing? If you get an error such as Error U041 or U043, the printer may just be low on ink or have a bad ink cartridge.
Does not recongnize ink cartridge
Error Message U053
Error messages displayed on the LCD and how to handle them
When an error has occurred in the printer, the error / check message is displayed on the LCD.
Take the appropriate action to return to the normal condition.
Error / Check message How to correct CHECK INK
U041 An ink cartridge is empty.
To cancel printing, press the Stop/Reset button.
To continue printing, press the OK button.
After the printing finishes, replace the empty ink cartridge.
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the printer cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
CanonPIXMA iP90 Color Ink Tank installation problem
yeah it sounds like a cartridge sensors are stuck or broken. i would say to replace the whole print unit. It will need a service support dealer to fit this part unless you can buy it and fir it yourself.
part number: QM2-2020-020
hope this helps
1helpful
Printer says ink cartridge not recognized.
Take the black ink cartridge back to the person who refilled it. The Microchip that's on the cartridge was not reset properly that's why the printer is returning that error.
You can try some steps before you take it to them to verify it.
1: reseat (take out and put back in) the cartridges into place
2: buy another black cartridge just to check if it will be recognized by the printer, if it does recognize it we know the cartridge is defective. If a new cartridge is also not recognize, start to check your warranty option with the manufacturer...
old marine
old marine
ZJ Limited
ZJ Limited
