Hitachi 60FX20B 60" Rear Projection Television Logo
Posted on Sep 19, 2007
60" Hitachi 60FX20B NOT WORKING
LIGHTNING STRUCK OUTSIDE CLOSE TO MY HOME AND TV QUIT WORKING, WHEN I TURN THE POWER ON THE RED LIGHT BLINKS AND TV CHIRPS A FEW TIMES AND SHUTS OFF. I HAD REPAIR SERVICE COME TO GIVE ESTIMATE FOR INSURANCE AND HE SAID THE AMPLIFIER WAS OUT. CAN I REPLACE THE AMPLIFIER MYSELF, IF SO WHAT WOULD THE PART COST. (ALSO THE SERVICE MAN BYPASSED THE BAD PART AND SHOWED ME THAT THE TV STILL WORKED, THE PICTURE CAME ON BUT NO SOUND.) IS THIS POSSIBLE?
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Sep 19, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
Helped
1836
Points
16
Yes they can run with parts out of the tv thats how he made the tv come on now that amp was shorted out (bad) and it was pulling to many amps a hevey load in the protection and thats why your tv did not come on. looks like you got your work cut out for you just get a new one and soder it up the part wil cost around $12.00 to $15.00 bucks good luck...and allso I dout he bypassed anything just taking the amp out bypassed it just soder a new one in its place and you be good to go....let me know how you made out...
Hitachi 60FX20B
Shop repair and very unlikely to get fixed in home
I have an Hitachi 60FX20B, there is a doubel image om the top half of the picture. The doulbe image is slanted at an angle. Any ideas?
Please replace two big black convergence output ICs in tv to solve this issue, soldering work is required to replace them and local tv repair shop will do that job if you are not familiar with doing so.
Required ICs are available in PartStore.com
Hope this will help.
Thanks.
Lightning struck now my tv won't work.
No,Ur power supply board have a big jolt massive power search.It dead,change the power supply board,will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
2helpful
2answers
I have a 60 in hitachi ultravision projection tv. lamo light blinking so I replaced the bulb and it still blinks,,
Hi,did you close the door cover?Make sure itsproperly shut other wise it won't tv light up. Reset the lamp
timer? you can do this by unpluging the set for 5 min
and plug it back(works for most sets). Was the fan
running ok? You can clean it w an air pressure
can. If you heard clicking or like wanting to turn on the problem could be with the board that powers the lamp.The board it's called the ballast.If its not able
to provide the power to the lamp it will not turn it on
and the red light will blink.Also did you get the original Philips lamp if you got a generic that
could be your problem.God Bless you!
4answers
No power
When I turn on the tv, there's the green light, that shows it's on, but it's blinking green and the screen is black
7helpful
2answers
My 50" hitachi ultravision won't turn on
i got a 62VS69A model type hitachi tv.... and it was thunderin and lightning outside all day .... and i left it on ... and when i woke up ... it was off..... and when i went to turn it back on.... it blinks blue,, then the light below it blinks red.... and the light below that light blinks red .... and then the first blue one again ... and over and over again ... untill finally it juss stays red... i donno whats goin on with this tv... im assumin it was the bad weather outside that did it but im not sure..... can someone PLEASE help a brother out ? lol
2helpful
4answers
Hitachi 55" LCD projector tv
Pixiling problem--replace light engine
need your tv model # to get part #......T
No video, no audio, red light on in front of TV
Excellent visual acuity technique!! I try to teach that procedure.
IC F6629B is probably shorted and at least one other part will
be open, possibly a zener diode,a fuse,a resistor or combo.
The service diagram would help.Be sure to use OEM first quality
parts.Let me know if you need more help.
1helpful
Hitachi 60FX20B
If you hear the unit comming on and theres no sound or Picture, then theres a fault in the horizontal sweep/HI Voltage circuit. This should not be fooled with unless you know the safty issues with HI voltage as theres voltage in these sets even after they are unplgged for a while. Good Luck
Top Hitachi Televison & Video Experts
matt martin
matt martin
Paul
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
