Question about Pelican Xbox Eclipse II Wireless Controller (XBECIIWICO)
I dont have a wireless receiver for my pelican xbox controller,,what should i do to connect it ???
Posted by trabesii hatem on
1 Related Answer
Anonymous
  • 165 Answers
SOURCE: i have a old xbox system and my wireless
Check to verify that your batteries are installed correctly.
- Check to verify that the power is on. Check to verify that the signal LED is blinking
If this does not solve the problem, do the following:
1. Make sure your Xbox is turned off.
2. Remove the battery lid and place 2 AA batteries into the Blade 2.4 Street Wireless Controller. Make sure the batteries are inserted as shown in the battery compartment.
3. Insert the receiver into your Xbox controller slot of your choice and power up the controller FIRST, then your Xbox.
4. Press the Connect button on the receiver once. Your signal LED light will begin to flash slowly.
5. Press the Back button on your controller. This will program the receiver to connect to the controller each time it is uses.
6. Turn on your Xbox and insert a game.
Posted on Aug 06, 2009
I don"t have a pelican receiver for my wireless gamepad,,what should i do??
buy the device you need or get the security of your reciever cracked by an expert giving you a multiple use of it like i got my reliance 3G modem security cracked running idea,tata docomo etc networks in my modem
Sep 23, 2013 | Pelican Xbox Eclipse II Wireless...
Controller will no longer sync to ps3
check batterys try with new ones, dont buy the cheap ones
Jan 09, 2012 | Pelican PL2045 XBOX AFTERGLOW PRO...
Cant get my xbox 360 to hook up to wireless internet
Hii go to the below link and you will find the complete details on how to connect xbox 360 to the wireless internet along with the screen shots..
http://tinyurl.com/raj321
Dec 26, 2010 | Pelikan PELICAN PL-3601 Xbox 360(TM) TSZ...
My network is using a linksys wireless G router and i can't seem to get the right settings put into the xbox menu because it doesn't find my network
hira895
In regards to your wireless connection issue with your XBOX 360 do you have the wireless adaper connected to the XBOX. Note most XBOX 360's do not have a built in wireless adapter, some of the Elites do but most do not.
Hope this helps
Issken
Nov 07, 2009 | Pelican PL-2050 XBOX EDGE 2.4 GHZ WIRELESS...
I have a old xbox system and my wireless controllers by pelican brand pl-2050 one will not link up to the xbox what to do!!
Aug 06, 2009 | Pelican PL-2050 XBOX EDGE 2.4 GHZ WIRELESS...
Wireless not working
Run the network tests from within the 360 menus - looking especially at the result for network address translation (NAT). If this is either limited or fail, you will need to change your router for one which is compatible with xbox live. Try xbox.com to work out which routers are recommended.
As far as your router kicking him when you connected your pc, then you must have altered the access permissions of the router maybe by accident.
If all else fails, turn off the pc, router, modem and 360. Find the reset button on your router and press/hold this for at least five seconds. Turn on the modem, then the router. Let that settle for a minute, then connect and setup 360 and laptop.
Apr 10, 2009 | Pelican PL-2050 XBOX EDGE 2.4 GHZ WIRELESS...
I just bought a wireless remote control for my xbox and i cant get it to work?
There is a little white buttom on your xbox , this is the sync buttom , on your remote there is a small round white buttom too ( sync buttom again ) press those 2 and it will find your new controller
Jan 26, 2009 | Pelican XBOX CONTROLLER WIRELESS- SPIRIT...
Pelican wireless gaming adapter
I have the same thing. The device is a P.O.S
Oct 23, 2008 | Video Game Consoles & Games
Playing xbox (NOT 360, the old one)
go to your nearest gamestop or ebgames, mine had 2 of them. :)
Oct 06, 2007 | Pelican PL-2043 XBOX SPIRIT WIRELESS...
Pelican Xbox Eclipse II Wireless Controller (XBECIIWICO) Logo
41 people viewed this question
Top Pelican Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Pelican Video Game Console and Game Expert? Answer questions, earn points and help others
