SOURCE: colors became distorted, then it shut off
Your tv has two problems showing up at the same time,the convergence IC's have loose conections in some of the conecting pins,the Ic's are mounted on heat sinks and can be identify by the markings on its face STK--- ---,3 letters and 6 numbers,one IC for each color,this pins need to be resoldered as well as any other loose conection or overheated areas in the board. The shutdown problem might be a resistor next to the output transformer,its value should be .47 ohms but it might measure open right now,the resistor is at the back edge of the circuit board on the right witch is the deflection board.If you are familiar with tv service you have a place to start but if you are not too familiar be safe and call for assistance from a servicer.Let Us know how it goes.
SOURCE: WD60C9 turns off for a few seconds
It is possible since the set intakes air from front and exhausts it from the rear you have a dirt buildup inside.
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
