It sounds to me like your battery needs to be replaced. The batteries lose their ability to hold a full charge after some time (especially if they've sat for a long while without a charge). You can get the battery tested at a trusted shop, but it might be more econimical to just replace the batteries with fresh batteries and see if that solves the problem. New batteries will charge much better and hold the charge much longer.
SOURCE: Thomas Train
It might need a new wire connection to the motor.
I would contact
http://www.shopjandl.com/
They help me with my ride on toys.
hope this helps
SOURCE: need Diamec 6V 4.5AH battery charger for Thomas the Train
For get the original over priced battery. You can purchase the same battery from the MFG! $8 and you can pocket the $60+ RIP-OFF
http://www.ebattery.com/Medical-Device/Diamec_DM64_BUP1013.html
SOURCE: have lost charger 4 ride
It looks like the charger has a specific plug terminated on the end so I would suggest buying the manufacturers replacement part. It can be purchased in the UK from the below links for around £35 or slightly cheaper form ebay but from a seller in the USA (third link below).
The charger model number is MECB0037.
http://totcars.co.uk/detail.aspx?ID=848
http://www.pedalpusherslimited.co.uk/pedalscat/peg-perego-replacement-6v-charger-p-515.html
http://www.ebay.co.uk/itm/220796543022
Hope this helps.
SOURCE: thomas train shows as fully charged however when
the music is run by three aaa batteries so that will work no matter what, did you reconnect the battery to the vehicle after charging it
SOURCE: need a battery charger for thomas the train ride
you can get one on ebay for about $6 shipped, just look for a 6v1a sla charger
