Gas grill wont lite manuallly
Do you mean it won't match light or the ignitor won't spark and light the burners? Or both?
If it won't match light or the ignitor sparks, but the burners don't light, that means you're not getting gas to the burners.
Check to the tank valve and make sure it's turned ON. Also, make sure that there's gas in the tank.
If both of those check out as OK, turn the gas tank valve OFF. Disconnect the hose from the tank and wait 5 minutes. Reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, light the burner farthest from the tank first and turn it to HIGH. Did the burner light and the flame height looks correct? If so, light the remaining burners following the same procedure. Now, are they all lit and the flames heights look correct? If so, you solve the problem. Just remember to always open the tank valve very, very slowly.
if the burners failed to light. Remove and clean all the burners, as well as the venturi valve on the open of each burner. Spiders like to build nest in the venturi valves.
if cleaning the burners did not solve the problem, you will need to replace the grill's hose/regulator assembly. You can find it in any home center or hardware store that sells gas grills and accessories, for about $30.00. Take you old one with you for comparison purposes.
Hope this helped you troubleshoot and solve the problem. Please be kind enough to let me know. Thanks and Happy grilling!!
