Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
A
Anonymous Posted on Sep 23, 2013
Transcend cefc unit will not power up. Glow light on power supply is on
1helpful
1992 Ford F350 7.3 Diesel, put in new glow plug controller, controller clicks off and on, but no power to glow plugs. What could cause this?
Hi Margaret , Does the glow plug wait to start indicator light on the dash come on ? And then go off after a couple of min. ? Check fuse K 20 amp in the under hood fuse box .This is one of three B+ power supplies to the glow plug control module > Two fusible link's are also B+ power supplies to the module . There is a 10 amp fuse located in the inside fuse box , fuse # 17 , this is power for the indicator light !
Glow plug light in cab do not light up and engin do not start
check the relay for the g-plugs as it is not supplying power to the glo-plugs. Check that there is power getting to the relay to energise it to get power to the plugs.. Probably a fuse is blown
Cefc d33193
the partion was rendered unreadable you can use harddisk low level format tool to format the device
Oct 11, 2013 • GPS
The glow plug light comes on at 75mph and stays on until the car is switched off,why does it do this? its a 1998 suzuki grand vitara 2.0td
the control /timer unit is faulty by the sound of it ,but it could be a wiring problem ,check that when it comes on next you are supplying power to the heaters if you are supplying power then either ignore it or renew the unit but they are expensive
2helpful
Won't start below 40 degrees, wait to start light does not even come on
Your glow plug controller is out, or there is an interruption in its power source, etc. Diesels are coldblooded by nature, and most need glow plugs to heat them up before starting in cold weather. The controller supplies the power to the glow plugs, but if it goes bad, or its supply of power isn't there, it won't start in cold weather, and that wait to start light which is also controlled by it won't come on.
Projector will not power on.
Since you see a the power button light up green there is a chance that the power supply is still good. Try updated the firmware. You can get it from the infocus website. If that doesn't work then something is wrong with the power supply. I can repair it if you'd like. My ebay screen name is gtitubro.
3helpful
HOW TO DOWNLOAD 2000 PICTURES ON TO TRANSCEND 8GB UNIT
WHAT I HAVE IS THE TRANSCEND 8GB CEFC JF V10 D33193  THIS IS ALL THE CODING ON THE BACK, AND IT IS A RETRACTABLE DEVICE WHICH PLUGS INTO THE COMPUTER, I HAVE IT TO BACK UP MY PICTURES, BUT DO NOT KNOW HOW TO DO THIS. I DO NOT HAVE THE MONEY TO KEEP ASKING ADVICE, THIS IS A SIMPLE ENOUGH QUESTION FOR ANY ONE WHO HAS A WEB SITE SUCH AS YOURS, THANK YOU FOR YOUR INTEREST, PEGGY
When starting from cold it is hard to start. It maybe a problem with the circuit to the glow plugs or the glow plugs themselves. Advice please.
try to change your power supply unit..
it mayb your power supply capasitor not working properly..
thanks
good luck..
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
