SOURCE: Water leaks during rinse cycle
My Washing machine is leaking in gearbox.the quality of water is bad (Hard)
SOURCE: Water leaking through detergent tray of my Hotpoint WF860
It sounds like the washer is not draining properly.
Remove lower rear cover of washer, locate and remove the large black hose fastened to bottom of tub.
remove plastic filter inside hose, and clean same.
Refit filter and hose, making sure it is on properly.
Be careful when you remove the hose, as there will be water in there.
As an extra precaution, remove soap draw,and thoroughly clean all parts, particularly,the conditioner parts
Please rate my fixya solution.
Thanks.
SOURCE: washing machine leaks from underneath after rinse cycle
i would 1st look to make sure the drain hose is not loose or broken. be sure it is staying in the drain pipe in the wall.it could be a cracked housing on your pump. hope this helps
