SOURCE: No sound from laptop - no sound icon in bottom right of screen
HI,
The sound drivers on the laptop are missing . Install the latest sound drivers from the folllowing link
http://tinyurl.com/yu5kvy
Download
1. Click Download Now, to download the file.
2. When the File Download window appears, click Save (Windows XP users will click Save) this program to disk and click OK. The Save In: window appears.
3. From the Save In: field, click the down arrow then click to select Desktop and click Save. The file will download to your desktop.
4. If the Download Complete window appears, click Close. The file icon appears on your desktop.
Install
1. Double-click the new icon on the desktop. For example labeled R12345.EXE.
2. The Self-Extracting window appears and prompts you to extract or unzip to C:\DELL\DRIVERS\R12345.EXE. (Example path). Write down this path so the executable (Example - Setup.exe) file can be found later.
3. The Self-Extractor window appears.
4. Click OK.
5. After completing the file extraction, if the Self-Extractor window is still open, close it.
6. Click the Start button and then click Run.
7. Type C:\DELL\DRIVERS\R12345 in the Open textbox and then click OK.
8. Follow the on-screen installation instructions.
Thanks
Proton
SOURCE: Toshiba laptop won t start up
try taking the hard drive out then switch it on without it then switch it back off, put the hard drive back in then it should work, if not try f8 then safe mode and do a system restore
SOURCE: acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
http://www.ubuntu.com/getubuntu/download
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
SOURCE: Laptop screen goes blank
try a live cd and if it doeasn't work on it then ur screeen is dead.
P.S.
live cd=bootable cd
you can download it from linux.com
SOURCE: Acer laptop and data projector: no communication
i have faced the same problem before 2 days ago......now i solved that one....i load my pc in safe mode....i adjust the screen resolution.....and i removed lastly i installed new software (it was typing master --- leave it this one).......after that i tried to connect acer laptop to sony projector (FN+F5) it's working properly.....try this.......please
