SOURCE: Codes to program Innovage Products Jumbo Universtal Remote
H have the jumbo universal remote from innovage pruducts. can you e-mail me all the codes? thanj you. [email protected]
SOURCE: remote code for my ge universal remote
hello and if you think the guy above me is too confusing then use my shorter version of what he is tring to say.
1.Press and hold both the tv and ON-OFF button
2.Press and release the PLAY button. If after five seconds, the component does not respond,
continue to press the PLAY button every five seconds until it turns off
3.When the component turns off, press and release the REVERSE button, then wait two seconds
to see if the If the component does not respond, continue to press the REVERSE button
every two seconds until the component turns on again.
4.press and release the STOP button. to save the program
..really is it that hard to say this
SOURCE: Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
SOURCE: i have a philips universal cl035a remote.i need
In the manual it say's that what you need to do is hold the code search button untill it stay's steady then press the function button (TV, cable or whatever) for the device you need to program before doing this though turn the TV or whatever on first. Then go to the chanel select up or + button and continue to press it until it changes channel if you over shoot it you can press the - or channel down button.
When you are were you want to be quickly press the mute button and release ( warning do not hold the mute button just press it quickly and release.) This will set the remote to the corect code.
Purchase original remote.Panasonic part # EUR 7627 Z 20.
Priced about 50-60.00 dollars......T.
