Question about Luggage & Travel
Are there garment bags that have wheels? - Luggage & Travel
Posted by jon david on
Nikole Brown
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 84 Answers
I'm sure, you can find such a bag. I recommend to check travel accessories stores https://travelsites.com/travel-accessories-stores/ for this purpose. They can provide you with a wide choice of travel bags. I'm sure, they will be helpful for you!
Posted on Aug 09, 2019
1 Related Answer
dracco111915
  • 5 Answers
SOURCE: how to replace wheels on hartmann garment bag
Some wheels are attached to the bags through screw or bolts, which are securing hardware and easy to remove. When such wheels need replacement, you can replace them by yourself. Some are attached to the bags through rivets, which require you to ask for professional removal and repairing service in case that they are broken. Some wheels of rolling garment bags can't be removed and replaced.
Posted on Aug 21, 2012
Where can I get a garment bag for a 40 inch suit?
http://www.amazon.com/40-Suit-Length-Garment-Bag/dp/B000AB286S/ref=sr_1_14?s=apparel&ie=UTF8&qid=1358340950&sr=1-14
Jan 16, 2013 | Luggage & Travel
How to replace wheels on hartmann garment bag
Aug 21, 2012 | Cars & Trucks
Spin is not fast enough for bath mat even with other items in washer. How do you activate spin indepedently?
Hello, Welcome to FixYa. I think what you're referring to..."tub mat will not spin fast enough to dry"... is not an intended function of the washer. I don't know if you purchased these machines yourself or have access to the owners manual/operation guide, but if you do you can verify what I'm telling you. Front load washers ( any washers really, but top loads are a little more forgiving ) are not intended to wash bath mat's or any single items. If washing a single item one must either select a "no spin" or add another garmet/item of equal size or mass to balance the weight of the load, otherwise the unit will not spin to it's potential...if at all. This is an exert from the Kenmore/Whirlpool operating manual... 1. To load washer Open the washer door by pulling on the handle. Sort laundry according to color and type of fabric. Place a load of sorted clothes in the washer. Do not overload washer. Overloading can cause poor cleaning. The washer can be fully loaded, but not tightly packed. Washer door should close easily. Mix large and small items. Avoid washing a single item. Load evenly. Wash small items such as infant socks in mesh garment bags. It is recommended that more than one garment bag be used and that each garment bag be filled with equal amounts of material. Hope this info helps clear this up for you. Let me know how that works, but that should fix the problem. Good luck. Thank you for choosing FixYa to day for your inquiry. Regards, Macmarkus :)
Mar 04, 2011 | Kenmore HE2 Plus Front Load Washer
Code F20, what is it and what do i do?????
The "F20" means no water is detected entering the tub or the pressure switch trip was not detected.
There is a good possibility the reason why is because some or all the water is coming out the dispenser. The reason why it's coming out of the dispenser is most likely due to a small garment was shoved up into the tube that delivers the water into the tub. This can happen if the washer is overloaded or if the garment is too small. Small garments should be placed in a garment bag before washing.
Remove the dispenser drawer and confirm there is no block there and then open the door and look at the rubber boot at about the 10 or 11 o'clock position and you should see where the water enters the tub. You will likely find a small garment up inside the tube restricting the fill water from entering the tub and causing the F20.
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Underware gets in pump its likesomething missing
There should be a filter screen (usually white) before the pump assembly. It should be installed behind lower front panel.
Also you can buy a fabric net clothes bag for the washer to stop small thin fabric items from going into the filter assembly.
Check your inside seal between the door and the drum for tears. If it is torn it will need to be replaced.
Nov 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My machine is tearing apart sweaters
Even in "gentle cycle"?
Use a nylon mesh garment bag (it has a zipper on it) available at Target, WalMart, etc.
Use a smaller one mesh bag for lingere, too.
Oct 13, 2009 | Bosch Washing Machines
Question==>JUKI dnu 1541 or ddl 8300n
Might I be so bold as to disagree with Allmakes.
Why would a manufacturer build different models of industrial. They are designed for differnt jobs. The 8300 is a high speed garment machine, the 1541 is a compund feed upholstery machine. The motor is the same HP and does not affect the ability to sew heavy. The garment machine will sew garment weight leather just fine but you will have problems getting the fabric to feed properly particularly over seams. The other issure you may find with a garment machine is it's ability to handle heavier threads. I suggest that the 1541 would be a better choice for making bags and purses.
Jan 26, 2008 | Juki DNU-1541 Mechanical Sewing Machine
Luggage & Travel Logo
851 people viewed this question
Top Luggage & Travel Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Luggage and Travel Expert? Answer questions, earn points and help others
