Question about GE Cooktops
SOURCE: Ticking Sound of spark igniter persists
excellent it worked thank you. but now the burner in the back of that side, the igniter doesn’t click?... I have to turn on the front first then turn the back on to have the gas get the light of the front. any idea what is wrong?...and would that be the switch or the igniter?
Thanks.
Posted on Nov 17, 2007
SOURCE: Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Posted on Aug 18, 2008
SOURCE: Viking Gas Cooktop - Ignition sparks continuously when in 'on' position
This is likely caused by either a dirty ignition electrode, a cracked ignition electrode, or a bad spark re-ignition module.
Clean and inspect the six electrodes for cracks, If that doesn't solve it order a new
Ignition module from an internet appliance dealer that carries Viking parts like Appliance Zone.
If you replace the Ignition module yourself, make sure to turn off the circuit breaker to the range/cooktop before you work on it. Also, make a drawing of where the different color leads are plugged into the ignition module before you unplug the wires and plug them into the new re-ignitor. If the unit is under one year, this should be covered under the warranty.
Viking had a recall a few years back on their ignitor modules.
Posted on Oct 27, 2008
SOURCE: GASS COOKTOP-electric ignition sparks continuously w/gas is of
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Apr 23, 2010
SOURCE: My Viking VGSU cooktop has the igniter go on conti...
My Viking stove igniter won't stop clicking. Both igniters on one side are clicking over and over
Posted on Jul 03, 2010
Dec 06, 2017 | GE 36 in. JGP628 Gas Cooktop
Oct 04, 2009 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Jul 29, 2009 | Jenn-Air 35 in. JGC9536 Gas Cooktop
Feb 24, 2009 | KitchenAid 31 in. KGCC505 Gas Cooktop
Feb 17, 2009 | Cooktops
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Apr 15, 2008 | Tecnik 27 in. TKH3515SS Gas Cooktop
Nov 22, 2007 | GE 36 in. Profile JGP962 Gas Cooktop
Oct 22, 2007 | Miele 35 in. KM326G Gas Cooktop
Sep 18, 2007 | Jenn-Air 36 in. CCG2523 Gas Cooktop
69 people viewed this question
