Question about Sony Computers & Internet
Sony VAIO VGC-RB34G PC Desktop CPU fan has been running on high for some time with occasional spin downs but any load on processor and it speeds back up. Then it began to beep once while trying to boot up but it would get into a loop and would not come up. I inserted a boot disk and somehow it came up and worked fine for a few weeks. Now it won't boot or beep at all. When I turn it on all of the fans work, the main CD drive opens and closes but nothing on screen and no beeping. HD "feels" like it is spinning. Could it be the CPU has failed? It has been a great machine for several years. Thanks in advance!
Posted by gwnail1 on
Unknown Person
    Sergeant:
  • 245 Answers
Read this user manual, it may help you to solve the problem
Posted on Sep 23, 2013
2 Related Answers
customers184
IT GURUS OF ATLANTA
  • 154 Answers
SOURCE: What lights should be on when the computer boot
You may possibly have a bad video card and a bad circuit on your motherboard. I would have the motherboard replaced. Some motherboards come with video cards, so once it is replaced, you may alerady have a new one with the motherboad part. If you not versed in doing this, you may want to get a professional to do so.
Posted on Nov 23, 2009
Anonymous
  • 96 Answers
SOURCE: Desktop will not boot into bios No Usb power;monitor ''No Signal''
Your problem is the memory . YOu have to put off the pc and remove the memory card in the slot. Then clean the silver pins in your memory with a rubber eraser. Put it back and see if the BIOS will be prompted on the screen , if not you have to replace the memory.
Posted on Feb 12, 2010
2answers
PC won't start up
It may be worth trying to re apply the thermal paste to the processor, make sure you remove power from the machine before you open it up. The CPU may have failed, but they don't fail very often, so try the paste first, it will only cost a few GBP for a couple of applications.
Sony VAIO VGC-RA810G Desktop overheats and freezes.
Following are the reasons for overheating, just take care of these things::
- Clean the Processor fan, Heat Sink and other peripherals
- Use High Speed fans
- Use CPU Heat Sink Paste in the processor
- Stop Overclocking your CPU
- Make sure your Heat Sink is placed properly above the processor
- Make sure your dint restrict the speed of CPU fan.
- Use Additional Cooling Units
- Shut down your computer at least two hour a day
Finally i will suggest you to get system utility program like PC Fresher. because it is a very useful tool that cleans your computer of temp files, history and cookies. Its also used to fix any registry errors that cause of overheating
How to install a power supply for vaio desktop vgc rb34g
Turn off power, remove plug from wall and power supply, Remove the 4 screws from the rear of the PSU. Open the side and unplug the cables. Remove the PSU. Refit is the reverse.
1helpful
2answers
Sony Vaio desktop VGC-RB34G has recently been shutting down abruptly without any warning or dialog boxes. The screen just goes black and the On/Off button does not respond. I have to unplug the unit to...
may be it will be your cpu over heating problem sou must clean ur heat sink and put heat sink compound on the top side of ur cpu, after you can install it heat sink back.if u stil have the same issue...just remove two screws from ur motherbord center screws. try it..
VAIO VGC-RB34G PC Desktop: is their anyway to install more than 2gb of ram in...
no, the only way to do it , is replacing the motherboard
I think is not worth
What lights should be on when the computer boot up. sony vgc-rb34g desktop . power on fans run at high speed keyboard lights flash hard disk light flashes mouse light on no beeps or codes no display on...
My sony vgc-rb40 will not boot bios with cpu fan connected
mostly all fans are 12V DC try connecting all the fans directly to SMPS of the system i.e the red and the black wire
Where is the vga connection on the vgc-rb34g
I am afraid to say that the Xbox does not have a VGA out connection on it. You would need a monitor with a component input or HDMI. Hope this helps :o)
Can't open DVD writer and Dvd Rom drive Sony Vaio VGC-RB 34G
There should be a very small hole on the front of the dvd plate. Push a small paper clip straight in. This should release the drive.
Computers & Internet Logo
Top Sony Computers & Internet Experts
Ekse
Michael Thomas
Michael Thomas
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
