SOURCE: How do I program a Directv remote witha Samsung Directv receiver
http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380052#h:1020.989
there is the website, put in the name of the receiver as Samsung and make sure you are under "SATELLITE SET TOP BOX" and follow the instructions on programming. hope this helps!
SOURCE: need a tv code for samsung LN40A550 so I can
you can pull the code from thew directv menu, go to set up, then system setup, then remote control, then to program remote. this will let you select samsung from the list of brands, it will then give you every code it could be
SOURCE: I can't find a code
Pick your remote here http://www.directv.com/DTVAPP/content/remote_codes
SOURCE: how to program DIRECTV RC71B remote to Samsung tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
