Question about Kenwood KM200 Chef Food Processor
Schematic kenwood km 201 speed controller - Kenwood KM200 Chef Food Processor
Kenwood service center kerala
Hi, Hope this helps.
Kenwood Service Centre Cochin Address Address :
Pukalakattil Building,
Mahakavi Vailopilly Road,
Palarivattom
City : Cochin
Kerala, India.
Pincode : 0.
Kenwood Cochin Service Centre Contact Details :
Phone Number : 9349519613
Website : http://www.kenwood.com/india/
Dec 13, 2014 | Kenwood Food Processors
No turning of motor in my Kenwood MX270 Patissier
Follow the power, start looking wherever the power stops. Sometimes it can help to reverse phase & neutral to track where the power stops from the other side too. You are only doing this for testing purposes and need to put it back as it should be when you're done.
Dec 08, 2014 | Kenwood MX270 Patissier Food Processor
Kenwood KM336 no power to beater or slow speed outlet
Hi. You have a broken gear in the gearbox either the first motion gear is loose on its shaft or less likely the vertical big gear is loose on its shaft. independent spares for the gearbox are available or complete gearbox
Aug 02, 2012 | Kenwood KM336 Chef Food Processor
Why is smoke coming from Kenwood chef A901
sounds to me like you may have burnt up the motor probaby by mixing to heavy of a load or running it too long, or by just being older. I would replace it as fixing it would be costly
Jul 13, 2010 | Kenwood Food Processors
Kenwood a710a mixer suddenly lacks power
sounds like the motor armature is burn. Dissemble the unit, remove the motor. Loosen the bolts running from end to end of the motor and with emery cloth, clean the small metal plates on the ehd of the armature. They should be bright copper colour. I the armature is burnt, they will be dull brown. The other thing is to replace the brushes in the motor.
Feb 04, 2010 | Food Processors
Kenwood KM200 Chef Food Processor Logo
Top Kenwood Food Processors Experts
Ross Keen
ADMIN Canada
ADMIN Canada
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
