Question about Humminbird 161 Gps Fish Finder Combo
When i power it on the screen just shows loading and never boots up
Posted by deborah webb on
lashingid
    New Friend:
  • 23 Answers
I don't have the same model but the same issue before the cable from the sonar was frade some and so it wasn't sending a good signal to the box so it just said loading I had to replace the sonar and then it worked fine
Posted on Sep 23, 2013
My Acer Aspire V5-571 does not load up it shows acer screen when turning on the laptop then loading floating ball comes on screen for a few seconds then black screen ? can any one please help ?
Hi Jim,
this seems like a no boot / no video kind off issue and mostly is coz of corruptions in softwares or drivers, try booting the computer in safe mode. if it does, then take a data backup. i would not recommend experimenting in this issue as it can crash the computer.
hence call 1-877-805-1027 for expert help.
Aug 18, 2015 | Acer Aspire V5 571-6614 : 1.6GHz Core i5 ,...
I have forgotten my pin code for my supersonic SC-74MID tablet. How do I reset it?
I don't know which OS your tablet uses... perhaps Jelly Bean. If so, if you push the Power button and the "Power Off" option shows up on the screen press the selection of "Power Off" and hold your finger down on it until a pop-up screen shows a selection of: Boot into "Safe Mode". Choose that and what happens is it boots up with no applications loaded. You should then be able to access the "Settings" and then choose "Factory Data Reset" option. Hope this works
Jan 08, 2013 | Supersonic 7" Touch Screen MID Tablet
My dell inspiron 1454 keeps looping on the boot up screen, then just goes back to the windows has filed to start screen..
Hi Charlotte,
The video doesn't show what you describe. The video shows that Windows is loading. Try booting in safe mode. Here's how:
Power up the machine. When the Dell logo appears, start tapping the F8 key until the Advanced Boot Options menu appears amd choose "Windows Safe Mode." Once windows starts, backup your data just in case. Then try to determine what it was you did last that may have caused the problem. Then try to start normally.
Hope this helps
Randy
Nov 02, 2012 | Computers & Internet
My dell notebook stoped working it shows only curser on the screen and there are some lines on the screen nothing wrong with the power supply
If it does boot to windows and only does not shows the icons..than you have to click right on the desktop and choose to show icons ..and will be ok ..If the screen you wrote about is just a start screen and it never started windows..than I think it is a windows fault and need to be reinstalled .Do that by entering the recovery partition and go with the total installation of the operation system ..
to do that choose the key indicated on screen and select the action ..
usually on start screen it is written to press F2 for the set-up and f12 for the boot menu and probably F11 for teh recovery ..if it is so ..just press f11 on start ..go to recovery ..choose complete recovery ..and will get it to the factory stage .
If the recovery do not work and you do have a disk for it ..insert the disk and boot from it ..try to boot to recovery with the disk on ..and see if ti works..if it dopes its ok ..if not ..restart . and press F12 to go to boot menu .and choose to boot from CD /DVD drive ..and hit enter .. this will force it to boot from disk and load the recovery .
same procedure with a boot-able disk with operation system, ..in case you do not have any recovery ..or just have recovery for drivers..and you will be forced to use a standard boot-able disk to load the operation system again
have a nice day ..and please rate my answer ..1
Dec 22, 2011 | Computers & Internet
Screen shows "Reboot and select
what you want do is disconnect your hard drive then disconnect the power from your motherboard the from the power supply, and press the power button the connect all the power cables back then enter bios screen go to the boot tab and select boot device priority and move your hard drive up.
May 21, 2011 | Computers & Internet
The XPS/Demension 400 desktop is having issues booting, it gets directly past the Dell loading screen then freezes. There are no numbers that show up on the face and if I press Control/Alt/Delete it goes...
First unplug all the connections from the pc. No cable at should be connected on the back. Keep pressing the power button for a minute completely without leaving it. Connect only the necessary cables which is power , keyboard and mouse ....nothing else.
Try if this works.....if no please reply for furthur help
Thanks!!!
Nov 18, 2010 | Dell XPS 400 PC Desktop
Gibberish + won't finish loading Windows
remove the new memory first. if that does not help you may have some a virus, indicated by safe mode workng fine. One other thing i found would do that is a damaged Hard drive, not to likely here because safe mode works.
Apr 28, 2009 | Dell Dimension E521 PC Desktop
I'va had this pc for about five years. It turns on past booting but once it gets to the windows xp loading screen the Monitor goes blank and shows a no signal message. The tower ( an emachine) still show...
u have problem of disaply scren resolutio for that
when u power up the computer press F8 key then u see safe mode and other menu
then enter in enable vga mode .
then u can change screen resolution to 1024*768 in dispaly property
Apr 23, 2009 | Sony VAIO PCV-V200G PC Desktop
Lg EnV VX9900 CLR Button Resets phone.
When you hit the clr button it will go back to the screen you where prior. When your booting up, it will show the Vcast screen. Maybe check your backlight setting.
Jan 17, 2009 | LG enV VX9900 Cellular Phone
My v3xx dosent wana turn on
check your battery 1st, maybe it is drain or not good anymore. and try to open it..if still the same gotta bring it to the service center .,here's what they do, check the fone if boot loads, if does'nt show the boot loader, it is a hardware failure, and they're going to test it if it is grounded , next it maybe the flex, the power ic, and flash ic,either of the 3, and if it show's they're put the cables in u'r fone and reflash your firmware, it maybe corrupted somehow.... to check if the boot loads,. press at the same time power,*,#.. if the info came out on the screen,., it only needs your firmware to reflash....
Apr 18, 2008 | Motorola Mobility RAZR V3
Humminbird 161 Gps Fish Finder Combo Logo
110 people viewed this question
Top Humminbird Boating Experts
Mike
ray gallant
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
