Panasonic PT-AE3000U LCD Projector Logo
Question about Panasonic PT-AE3000U LCD Projector
Hi there, I'm having a strange problem that has really confused me and I'm sure it's something simple that's tripping me up but I can't figure this out. -Im not getting an image from any of my HDMI inputs. -It stopped working suddenly, which leads me to think either damage to the inputs themselves or someone in my house messed with my settings. -I can however get an image using RCA, so the bulb etc are all working fine. -When I plug the projector into my pc through HDMI it recognizes it which presumably means the HDMI inputs are working on some level. - I have tried lots of things but I'm sure I have missed something simple. Any help would be greatly appreciated.
Posted by Tom Stevenson on
magna buff
  • Panasonic Master
  • 3,828 Answers
If you can select the hdmi inputs ok
and swap them around without a good result
if no image etc
you would expect there to be a default no signal message or error something on the viewing screen
if a total blank
could be possible the Projector unit has a internal board failure
Panasonic PT-AE3000U Operating Instructions Manual - ManualsLib
https://www.manualslib.com/manual/246284/Panasonic-Pt-Ae3000u.htm
Posted on Apr 01, 2017
5 Related Answers
Anonymous
  • 17 Answers
SOURCE: Panasonic PT-AE900U displays black and white only
sounds like bad cables, or wrong setting on projector you may have it set to compoent instead of composite,, you don't tell how you are hooking it up. (what type of cables you are using)
Posted on Jul 17, 2008
SOURCE: Panasonic PT-AE900U Projector Lamp stops working (intermittent)
since it has worked 1200 hours or even more since u have been resetting the counter! just change the lamp, resetting the counter does not make the lamp work or not work , it is only a reminder for the user to change the bulb when it should be & that u have some balance hours left to procure a new lamp!
if the brightness is adequate, then it is a ballast problem & not lamp problem!
buy a new lamp as u will anyway need to , fit it & it may solve ur problems permanently!
Posted on Feb 08, 2009
Anonymous
  • 6 Answers
SOURCE: Blueish tint on picture
no... lcp panels will look different when going bad ! this is the polarization filter, most of the time the one BEFORE the lcd panel (blue in this case). these should be cheap but are not easy to get...so you might pay quite a lot. you can also buy polarization filter sheets and cut them to size. keep in mind to check for the right orientation !
Posted on Jun 10, 2009
electronios
Anasty B.
  • 126 Answers
On the iris unit, mechanism stops moving and needs cleaning and greasing, but for best results must be replaced.
Posted on Feb 23, 2010
Anonymous
  • 57 Answers
SOURCE: I have Panasonic PT-LC75U bought
Steve, your issue is not the bulb...
Sounds like you have a problem with either a ribbon cable from your main board to red LCD panel, or a main board failure.
Posted on Aug 15, 2010
3answers
Power went off on my microwave when I accidentally ran it empty for 7 mins. Today my husband tried it and it seems OK, is it safe to use again? Thanks
If you are not sure in ANY way about using this microwave BUY a new one. Simple as that!!
As long there where no sparks, strange noises or strange smells you should be OK to use it. Most modern microwaves have safety electronics built in that can act as a safety switch.
You can buy 'Plug In' adapters that are designed as a safety circuit breaker. Try searching for "Plug through RCD adapter". These 'Trip' if there is a power surge stopping the power to the item plugged into it. I have one for when I use big power tools.
1helpful
Plug it in and the GFCI trips.
before you scrap it , me id plug it into a regular circuit an try it and if it still trips breaker then yes dump it, IVE seen this happen plenty of times , really you shouldn't plug devices into a gfci that have motors in them , they will most times false trip and shut the device off , this is especially bad when its a freezer in a basement or something motor driven appliances and gfci's don't play well together .
Just installed a new Hayward superpump. Using an intermatic timer (not sure which model, but found something close in a search). Yellow face, A,1,2,3,4 terminals. I wired the new pump like the old pump...
You have 240 volt 30 amp breaker
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-8-8.jpg
A 1 2 3 4 sounds like 240volt T104 or 240volt T106
These look the same but are two different timers.
The T104 is made for regular on-off operation, while the T106 is made for 2-speed pump.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Now is the pump 240Volts, or 120Volts?
Look at nameplate on motor.
Is the motor single speed or 2-speed?
If pump is 2-speed, then motor will have 3 wires, and nameplate will say Hi and Low.
There is usually a yellow wire with 2-speed pump.
NOW, lets suppose you have 120Volt single speed motor.
You can convert the 240Volt T104 into 120Volt T103 timer by changing the clock motor from WG1573 to WG1570 available at WW Grainger. And then switch white wire inside breaker box to make circuit into 120Volt circuit.
If you have T106 2-speed timer, it can also be converted to 120Volt using same clock motor change-over.
Add a comment and describe your wiring very carefully. Include voltage and exactly which wires are connected, because the description of 'terminal 4 and L4' was too confusing
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2answers
I dont understand how to create a password can u help me
1-Creating a password is simple...creating one that is memorable AND strong is not so simple. First, think of a word that describes you. Example: I'm funny. Word: funny
2-Next, think of something you like. This could be your favorite day of the week, a color, a time of year, a movie, a band...etc. Just make sure it's something you know how to spell. Example: Black or Friday
3-try a number, may be your date of birth, house number, Id no etc. Example- 1990
4-Finally, find a way to string them together with numbers and other letters. Example: funnyblack1990 or funnyblackfriday
5-You can make the password even stronger by adding uppercase and lowercase letters: Example : FunnYBlacK1990
Note:To mix it up one more time (and really confuse the infiltrators,) try using a letter that sounds like the way yours is spelled: Example: FunyBlck90
Hope this will help. Thank you for using fixya !!!
1helpful
Service engine soon light.
Hi:
There are hundreds of things that trip that light. You need to have your vehicle codes scanned to see what has caused it. Most auto parts stores will do this for free. It could be something as simple as a loose gas cap, but this is an easy way to figure it out!
2answers
The service engen soon lighted just its lighted and there is no strange sound appearing
Hi:
You need to have your code scanned to see what tripped the light. It could be as simple as a loose gas cap, or hundreds of other reasons. Most local auto parts stores will scan your code for free, so you will know what is going on...
9helpful
2answers
Power head not working
There is a gray button next to the red "power on" button that powers the brush unit. If the unit has tripped the reset for some reason it must be reset. This can be done by holding the gray button down for ten seconds while the unit is not running. When you power it up after this reset, the brush unit should run.
2answers
I have several (20 ) Dell GX280 standard desktop machines which upon switch on do not boot. The problem is the system board. The processor fan, after a short while, races. Is anyone aware of a mod or fix...
Have you tried to flash the BIOS? I am sure that you though of this, but sometimes we techie's have brain block.
Are they any jumpers on them?
Have you swapped the memory around?
Just trying to jar your memory on things to check. I am sure that with (20) of them that you are pretty frustrating. What does Dell say? Curious to find out what you figure out. What motherboards are in these? Are they all the same motherboards. Stupid question, but just wandering. I would be really mad if it were me. I am sure that you have thought of everything. I f you let me know what you have tried, I might be able to think of something that you have not tried. I just looked these up and they got great reviews. Strange that none of them work. Have you tried the processors and memory in other machines? Keep me posted on what you figure out.
1helpful
2answers
Hitachi 500GB External- strange tones at startup, won't recognize
It sounds to me like there is a seek problem.Is this the sound coming from the inside the box itself? If so, that is NOT good. Usually when you hear crazy noises like that from a hard drive, its internal damage. I imagine when you tripped on the cable and it fell to the ground, it exceeded the g-force rating for the drive. That and the fact it was under power and doing read seeks, the heads could have crashed. I guess you could disassemble the unit and hook up the hard drive as a slave inside your computer and bypass the external unit to see if that solves it. Its worth a try. It really does sound like its not a good situation. Sorry about that. I hope this helps!
Me again, I'm just getting really bummed about my 105....
I too own an E-105 and we can at least be glad we have the 105 and not the 100 model. We have 32 mb of ram rather than 16. Unfortunately we also have something that is getting older by the minute. Our cpu is a MIPS R4000, so when you see software to download, make sure it is MIPS compatiable or you are SOL. And then not all MIPS software will run. I like to kill time too, luckily there are chess, checkers, backgammon games out there that run on our machines. If you are looking for super graphic killer type games...you are severely limited. I don't listen to music much on mine, I mean why run out of power on a pocketpc for music when you can buy a stereo radio which if you lose, isn't the end of the world. A hard reset isn't a bad idea when it gets too confusing, and is simple to do. The best thing is just to install each program one at a time and make sure they work before installing others.
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mehandi Husain ...
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
