Question about Wolf Range 18 in. SPR-100 Gas Cooktop
LOOKING FOR HEAT CONTROL KNOBS FOR CORNING COOKTOP MODEL KC-iR RANGE. KNOBS SAY C777
The indicator light for the stovetop remains on despite all the knobs for each element in the off position. One of the elements is still getting power and heating slightly despite all controls in the
Hello friend, thanks for your post!
I see that the indicator for your cooktop continues to remain on for your Frigidaire range. It sounds like it could be a potential issue with your switches or control panel. I would recommend a reset on your range which you can do by flipping the household circuit breaker off for ten minutes. I hope this is helpful. -Matt
Oct 11, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
Can you use metal cookware on the old Corning Glasstop ranges? If not, what do you recommend?
Yes. I use metal pots and pans on mine for years. They need a flat bottom. Heavey bottomed pans work best - Thin pans don't transmit the heat well,
Mar 09, 2011 | Verona 34 in. CTG536S Gas Cooktop
I need a Thermador griddle control/ignitor & a light switch knob
We are Thermador factory authorized service and parts suppliers. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
and we can get your ignitor and light switch out to you asap.
We look forward to working you. Thanks, Ella
Nov 10, 2009 | Thermador 37 in. SGSX365 Gas Cooktop
Why is the light burning on my Corning glass cooktop?
well there is some problem with ur knob u should replace it.
Jul 21, 2009 | Verona 34 in. CTG536S Gas Cooktop
Wirlpool elect range GR465LXLS, cant control heat on dbl burner
yes it is your control infinite switch the knob swicht that goes from 1 to 10 or min to max thanks from gilles
Mar 13, 2009 | GE Cooktops
Amana Electric Smoothtop Cooktop heat control knob.
1st remove the control knob by off position & pull it one by one then clean it by using vacium.tnx
Nov 16, 2008 | Amana Cooktops
Stove knobs...
if the model number used for this listing is accurate then you can find your knob here
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1173229&PPStack=1
Sep 28, 2008 | Maytag MEC5430BDS Electric Cooktop
Wolf Range 18 in. SPR-100 Gas Cooktop Logo
64 people viewed this question
Top Wolf Range Cooktops Experts
Alan Chouinard
Paul Carew
ray gallant
Are you a Wolf Range Cooktop Expert? Answer questions, earn points and help others
