It will be best to do a code search method. If you wish to get more details about this, check these sites.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and press 'Enter'
or view it in Mosaic / Timeslide option.
SOURCE: universal remote code needed for motorola cable box (for comcast)
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC8800
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you
have one the "magic" button for three seconds, a light should then
flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
http://www.ofausa.com/remote.php?type=URC3220
you do
this by either holding down the device button eg: TV or if you have one
the "magic" button for three seconds, a light should then flash twice
Many thanks
Mark
(www.sparky-uk.com)
SOURCE: Code for remote
To program your URC-3021 remote control to operate your TV, the remote has a code search
function.
To search for a code for your TV:
Hope that helps.
