Brookstone TinyTunes  MP3 Player Logo
Question about Brookstone TinyTunes MP3 Player
My problem is that my mp3 player won't work unless it is charged to something other than that it won't turn on.
2helpful
Just bought this mp3 player and it will not turn on unless its plugged into the computer/charger.. No music and never been used till I opened it. Please Help!!!
The new player needs to be charged overnight for the player will work on the battery. You may need to do this a few times after the battery runs down.
I just bought the eclipse cld and it won't turn on after charging for hours
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
2helpful
Sony walkman Sony Walkman Bean NW-E305 (512 MB) MP3 Player won`t charge
Good morning, afternoon, evening or night; whatever time of day you are reading this solution post. Thank you for choosing FixYa to assist you with your problem. Your Sony Walkman Bean NW-E305 (512 MB) MP3 Player won't charge properly? Well Danish, we must use a method called troubeshooting to figure out and solve this situation. There are several reasons why this player may not be charging properly. The cause is either coming from the battery inside of your MP3 Player, a bad or faulty USB cable connection, or something (software) isn't installed correctly. Let's look at the first cause- The battery. The battery life may be gone. If it is, you will need to replace it if possible. Your device takes a
I have a rca M4304 mp4 and it will not turn on unless i plug it to the charder and when i unplug it it truns right back off
Ifthe MP3 player battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
2helpful
My ematic mp3 player will not turn on and it is fully charged. I had realized i overcharged it and it wouldn't turn on so i just clicked on reset and now it won't turn on, even when i plug it into the...
You shouldn"t be able to over charge it.unless there is something wrong with the unit.i had a simular problem with my Zune.it was fully charged but as soon as i unplug it it would not power on,it would only work when plugged in,i had it replaced under warrenty.call your manufacturer.
Noggin
the player has to be connected to computer via USB cord one end goes into the mp3 or mp4 and the other goes into the usb port after it has charged to turn it on u have to hold the menu button down/ Thats how mine work Does anyone know how to add videos I have added pictures which looks beautiful.
Still wont work
try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
I hope it won't keep freezing on you after the update
Open Questions:
Top Brookstone Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
 Mike M
Mike M
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
