Question about Hardware & Accessories
Utilitech 2 outlet timer - 0155671
As stated it has 2 outlets. Can each outlet be programmed independently?
Posted by superman 30528 on
Gene Haynes
  • Hardware & A... Master
  • 5,391 Answers
No.
Each outlet has same on-off programming.
Utilitec does not make 2-channel timer.... and neither does any other consumer timer company... unless you buy a box timer like Intermatic ET 1100 or 1800 series etc 2-4-6-8-12 channel timers.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET-series
To have 2 different programs from same outlet, then buy 2 bar timers that both fit same outlet, and then program each to suit need.
http://waterheatertimer.org/Woods-timers-and-manuals.html#bar
Many bar timers are 24-hour instead of 7-day.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Sep 23, 2013
2 Related Answers
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: i have a new utilitech
Would like to know if you have got the timer to work
Posted on Oct 22, 2010
Anonymous
SOURCE: are you able to share
Open following links:
1) Basic written instructions:
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
2) Instruction pdf manual for identical Woods 59377 timer showing programming plus how to set countdown and random feature, summer-winter changeover, load ratings.
http://waterheatertimer.org/pdf/Woods-59377.pdf
3) More resources
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Aug 28, 2011
Will a utiltech indoor timer #0155671 work outdoors?
Yes but maybe it will not last very long.
Utilitec 0155671 is indoor timer with 2 grounded outlets.
Indoor timers will work outdoors until they gets wet from rain, wet from evening dew, or overheated from exposure to sun.
Jun 21, 2012 | Woods Industries 59377 Indoor Digital...
Are you able to share instructions for a Utilitech indoor digital 2-outlet timer? Item #0155671
3) More resources
Aug 28, 2011 | Hardware & Accessories
Indoor timer 0155671 it wont turn on or off after programing
Utilitec 0155671 7-day digital programmable timer is sold under different brand names and numbers
Read instructions on following link.
There are 7 general things to look for if digital timer is not working correctly.
1) 0155671 timer is considered incandescent light bulb timer (tungsten) and not necessarily made for motors loads, TVs, CFLs etc. Try using timer on table lamp with incandescent bulb. Turn lamp ON, and make sure bulb is good.
2) Outlet is wired wrong: test outlet with circuit analyzer, and try timer on another outlet, and with different load. For example if outlet polarity is reversed, or if load has interference.
3) Timer is programmed for ON times but not for OFF times.
4) Programming has conflicts, for example program1 ON is for 8am Mon but program1 OFF is for 11am all-days-of-week.
Or program1 and program2 ON-and-OFF times conflict.
5) Timer is not set in AUTO mode, and timer is in random or countdown mode.
6) Timer is defective: 6-8% of all timers arrive defective.
7) If timer is older, the internal battery may be fading. Battery is not replaceable. These timers have 1 year limited warranty.
Jul 11, 2011 | Hardware & Accessories
I have the Utilitech #015550 outdoor 2 outlet timer. Can't find the instructions. Can you help? Thanks
May 2011: Utilitec 015550 is not enough information to identify timer at this point.
New timers come on the market.
Do one of the following to find best answer
1) Add a comment and describe timer in detail.
2) Add a comment with in-focus photo of timer posted on Flickr.
3) Open following links to identify same-similar timer, and add a comment if needed:
Upvote the help.
May 30, 2011 | Hardware & Accessories
I have a one outlet utilitech timer and forgot how to set it ....help
Utilitec makes 2 different plug-in timers.
Utilitec 0155671 is about size of baseball and has 5 buttons and two outlets. Programming is shown on link below.
Utilitec 0144506 timer is small and rectangular with 5 buttons and slide switch located on top of timer. This timer can turn lights on-off once a day and has 1 outlet. 0144506 Instructions are given in steps shown below.
Also see:
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
Steps:
-Plug timer into wall for 1 hour until rechargeable battery is charged and display shows.
-If battery will not charge, then check electricity to wall outlet, if electricity is good and battery will not charge, then timer is no good.
-Lamp has to be turned on for timer to work. Check bulb if timer stops working.
-Unplug timer to set program.
-Press reset button with paper clip to remove any programming.
-Slide switch on top of timer to 'Timer'
1) Set current time
Hold down Time button
Press HOUR until current hour am-pm shows in display.
Press MIN button until current minute shows
Since this is a one-day repeat timer, no day program is available.
2) Program ON > this is when you want lamp to turn ON
Hold down ON button.
Press HOUR until ON hour with am-pm displays.
Press MIN until ON minute displays.
2) Program OFF > this is when you want lamp to turn OFF
Hold down OFF button.
Press HOUR until OFF hour with am-pm displays.
Press MIN until OFF minute displays.
3) Set timer to operate
Make sure slide-switch on top of timer is set to 'Timer' to run program
Plug lamp into timer, and then plug timer into wall outlet
For manual override, move slide-switch to 'On' and light will stay ON
Nov 27, 2010 | Day-Timer Hardware & Accessories
How to program utilitech 2 outlet timer
Push all the pins down. Pull them up for on/off times. Set the clock by turning the dial to current time. Plug it in. Plug timed items into timer outlets. Warning: Both outlets will turn on and off at the same time.
Dec 16, 2009 | Green Air Hardware & Accessories
How do you program the utilitech 1-outlet daily timer
How do you program the Utilitech Outdoor 6-outlet Stake Timer
Dec 01, 2009 | Day-Timer Hardware & Accessories
Hardware & Accessories Logo
645 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
