KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
An F6 error code typically indicates a controlpanel problem. Disconnect power and wait several minutes before plugging itback in. If the F6 error code comes back within a minute of restoring power,the control switch pulse return line is not connected properly. This willgenerally require professional repair.
Hi. this code represents a key pad or control board malfunction. you will have to make sure the key pad or control panel connectors are connected tightly and securely. If the wires and connectors are secure, the actual control board may be faulty and you will need to replace it at this point.
F6 is a communication error. It is either a loose connection to the control board, or the control board is shot. They should have diagnosed this when they came out to fix it. Open it up, and look for loose connections. good luck
