Televison & Video Logo
Melissa lobo Posted on Sep 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tv flickers constantly now. Only 2 years. Flickers with anything --Netflix, cable, DVD, dvr, etc. Tried to change connection to different HDMI sources but problem continues. Help!!
Russ Hill
Level 3:
  • Televison & ... Master 4,057 Answers
  • Posted on Sep 22, 2013
 Russ Hill
Level 3:
Answers
4057
Questions
10
Helped
1177553
Points
12696
Does it do it on any other use ie tv free view scart or avi. is it just HDMI lead connections it could be a lose HDMI socket connetion that will need re sodering back on or that board is failing and need changing.
1helpful
HDMI from new laptop is causing intermittent flickering.
i would suggest a different refresh rate. should be in display properties.
1helpful
Why is there no picture but sound?
Can you tell us a bit more about the problem? It would be helpful if we knew:
1) What device are you using to connect to Netflix (computer, DVD player, TV, etc.)?
2) When you use that device for something other than Netflix, do you see a picture? So if you're using a DVD player, can you play DVDs? Can you watch TV?
3) Can you log into your Netflix account on your computer and watch movies on your computer? Can you login from someone else's computer and try that?
3) When did the problem start?
Some shot-in-the-dark steps that apply to all electronics:
1) Turn everything off. Turn it all back on.
2) If that doesn't work, unplug everything. Wait 30 seconds, then plug it all back in.
3) Check all the cables (from power to your TV and Netflix device, cables coming from your peripherals to the TV, etc.). Even if they seem to be well-seated, unplug them and plug them back in.
4) Try new connections. If your TV was connected by HDMI, and you have a different way of connecting your device (DVI, component, RCA, s-video, coax, whatever) try it. If your device connects to the Internet wirelessly, see if you can get a wired connection. Swap cables wherever you can.
5) If you can, try interchanging components. So, for example, try connecting to a different HDMI port on your TV. Try other devices on your TV. Take your Netflix device (if it's not your TV) to a different TV.
Those last 2 steps may solve the problem, but are more likely to isolate the problem. (For example, if your DVD player doesn't work no matter what TV it's connected to, then the problem is the DVD player.)
Update us with as much info as you can.
Mar 29, 2015 • Netflix
2answers
How do I hook-up Netflix through a Sony Blu-Ray player and a LG television
If your Sony Blu-Ray player and LG TV are recent models, each should have an HDMI cable connection. HDMI is an method to connect your digital video and audio devices with just a single combined cable. In the case of your LG TV, using an HDMI cable will allow you to send the HD video signal to your TV's screen, and allow you to hear the sound through the TV's speakers.
Your LG TV may have multiple HDMI connectors, to allow other devices to send signals to your TV, such as a cable box or satellite box or digital video recorder (DVR). Your Sony Blu-Ray player will usually have just a single HDMI connector.
Purchase an HDMI cable from your local electronics store. There are different versions of the HDMI specification, and you should get a cable that you can verify is certified for the HDMI version 1.4 specification.
Plug one end of the HDMI cable into the Blu-Ray player, and the other end into one of the HDMI connectors on the TV, noting which one you selected.
When you turn on your Sony Blu-Ray and your LG TV, you should use the remote for the LG TV to select the input source. Your LG remote should allow you to select the HDMI input connector you used, at which point you should see the display of a DVD playing on the Blu-Ray player. If you cannot hear the sound, use the LG remote to increase the TV volume.
Mar 02, 2015 • Netflix
1helpful
Help with HDMI cable error
Try a new HDMI cable. There was an "upgrade" in the firmware for HDMI and i'm guessing netflix upgraded which means your four year old HDMI cable is obsolete. My reasoning may be wrong but twenty dollars is much more affordable. and most likely your problem.
switch the HDMI cable end for end, maybe try a different port
Can't record from box/dvr to a dvd-r
get a new one amd instage it and tell the manger that it is not working
Screen flicker when connected to PC through HDMI
the flicker will be the pc you have a low voltage on the hdmi board were by the voltage is up and down causing the flicker. could be a low volt on the psu or in the graphics card itself. graphics cards use a lot of power. could just need removing and given a good clean.
The TV model is Sanyo DP32648. DVR Cable Box - Motorola DCT6412 III I have a DVR cable box connected via an HDMI cable to the TV's HDMI 1 slot. I have had the TV for around a year now and haven't had...
If you have the DVR connected to the TV with the Coaxial and the HDMI that is probably causing the problem I work for a Cable company and have dealt with this problem on numerous occasions. Try just disconnecting the Coaxial cable from the cable box that should fix this issue.
2helpful
I am having connection issues with an LG 55lh40 television, a HD DVR from Directv, a PS3 and a DVD/VCR combo. The TV seems to be working good, but does not seem to be picking up an HDMI cable of any kind....
No picture
when connecting HDMI:
Check HDMI cable over version 1.3.
The HDMI cables don’t support HDMI version 1.3, it cause flickers or no screen
display. In this case use the latest cables that support HDMI version 1.3.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
