I have got a 125cc stomp pit bike engine and it won't start a friend looked at it and said he thinks its to do with the clutch and something not moving when it should he thinks that something moves in the middle of the clutch and is jammed but I have no idea what he means and I really need the engine running again it's a manual 4 gears all up stomp 125cc
SOURCE: 1100 wierd clutch disengage problem
Bleed your slave cylinder on the sprocket cover and refill the hydraulic fluid. If you have any leaks you will get air in the system and it will not fully disengage the clutch. As for the 750, they have cable clutches and you just need to adjust the slack of the cable.
SOURCE: clutch snatching Madass 125cc
Could be burnt, or scorched clutch discs. DId you check the oil lately? I believe the Madasses have a wet clutch, right? Hope you didn't burn up the whole clutch basket. But you may have. Check the oil now!!!
SOURCE: flywheel doesn't spin on kick over
Flywheel has a keyway that has been sheared or bolt on shaft is loose.Either way you need to pull the flywheel and inspect it...replace keyway..reinstall retorque...Good Luck to you my friend....Tim
SOURCE: clutch rm 125
Okay, this may take a couple of comments back and forth but I can get you back on the road. First, Have you done any work on the clutch lately? If so, what and why? Did the clutch work okay after the work? Have you changed gearbox oil in the last month or so? If so, EXACTLY what oil did you put in the gearbox? i.e. "10w40 Mobil Super Blue fluid with silicone friction limiters". Just post a comment to get back to me.
