HP Color Laserjet 4730 MFP scanner not initializing
HP Color Laserjet 4730 MFP scanner not intializing
Posted by varughese on
Murad AL-Shishani
    New Friend:
  • 41 Answers
Open the scanner's glass cover ,,, there is a white sensor on the backside of the glass ,,, clean it with a little wet fabric ,,, then change the scanner unit's place to be exactly under the sensor ,,, close the cover ,,, turn on the power ,,, and give me a good rate ,,, :)
Posted on Oct 27, 2013
2 Related Answers
Anonymous
  • 11 Answers
SOURCE: how do i scan images using the hp 4730 mfp
check under general reference (link below). it should mention how to fax, e:mail and copy. if you copy to file / pc that should work as the scanner.
otherwise make sure the "scanner" facility is installed as some MFP's do not come with all facilities installed. (and therefore may not give the option on the screen.)
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=468688
Posted on Jul 21, 2010
Anonymous
SOURCE: SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Posted on Feb 04, 2011
How do i connnect HP LaserJet 100 color mfp M175nw to my wireless network?
try with HP Support website, you can find guides and all you need for yours hp devices
Mar 05, 2016 | HP LaserJet Pro 100 color MFP M175nw -...
Initializing scanner please wait
Reset the NVRAM should fix the problem. Get the NVRAM reset procedures from HP support site or Google them. Regards, Mike
Apr 03, 2014 | HP LaserJet 4730 MFP Printer
Scanner lock indicated
There is a slider under the scanner unit or on the top right rear of the top of the printer. switch the other way and it should work. Good Luck
Jan 12, 2014 | HP LaserJet 4730 MFP Printer
Hp 4730 fuser reset
Anyone with information on how to reset the Fuser page count without chanigng the fuser on HP 4730 MFP? The fuser in the unit is in very good condition and replacements are not cheap. Any help would be much appreciated.
Mar 12, 2012 | HP LaserJet 4730 MFP Printer
HP Color Laserjet CM4730 Scanner Not Initializing
I had an issue similar to this and it was fixed by replacing the memory dimm on the bottom of the formatter.
Nov 17, 2011 | HP LaserJet 4730 MFP Printer
How do i scan images using the hp 4730 mfp
Jul 21, 2010 | HP LaserJet 4730 MFP Printer
How do i cold reset a HP CM6040F MFP COLOR LASER PRINTER It doesnt complete the initilization process... keeps hanging on step 6
restart the printer hold down 6 when backlight illuminateshold till all three lights turn on,relese 6 keythen press 3 or 9 to scrool
press 6 to select the optionu want then enter cold reset starts......
Jul 14, 2010 | HP LaserJet 4730 MFP Printer
I have no disk for a HP color lasrjet 4730 mfp and can't install on my laptop
Check out this link. You made need to copy and paste in browser.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=468689&taskId=135&prodTypeId=18972&prodSeriesId=468688&lang=en&cc=us&submit=Go%20%BB
Jul 06, 2010 | HP Color LaserJet 4730xs MFP Printer
When sending print jobs to the HP MFP 4730 device keep processing job and data led keep blinking with no printing
this problem comes due to formatter card it is faulty replacur problem will be resolvee them it will work ...........
Jun 17, 2010 | HP LaserJet 4730 MFP Printer
My HP cm4730 won't make make copies, It still prints fine
have a professional take a look at it to see whether there is any internal damage that disallow for copies to be made.
Jun 11, 2010 | HP LaserJet 4730 MFP Printer
381 people viewed this question
Marvin
Marvin
