Will heat shrink cartridges fit the Dymo Lableport 250??
Posted by Rick Andrew on
DYMO Support
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
There is not such model. If you mean DYMO LabelPoint 250, then it is not going to work. The heat-shrink tube were designed for industrial printers (RHINO 4200, 5200 and 6000).
Posted on Sep 23, 2013
HOW DO I REPLACE THE FRAYED CORD?
If you can not figure out how to open the adapter case the easiest way to eliminate the frayed portion is to cut the cord on both sides of the frayed area. Make sure you mark one of the wires before you make a cut so you can match them back up when you solder it back together. Get some heat shrink tubing which will fit over each individual wire as well as a piece that will fit over both wires which will be covered with the smaller heat shrink tubing.
Once you cut out the bad portion slide the larger piece of heat shrink tubing onto the longer remaining wire as far from the cut as possible. Next slide a small piece of heat shrink tubing onto one of the split wires, again move it as far from the cut as possible. Strip about 1/2" of insulation from the cut wires. Wrap the stripped wires together making sure to put the marked wires together. Solder the wires together. You may want to hold the end of the wire closest to the heat shrink tubing with a pair of needle nose pliers to act as a heat sink so the tubing doesn't begin to shrink before you slide it over the solder joint. Now, slide the smaller heat shrink tubing over the solder joint and apply a heat gun to it. Slide the larger heat shrink tubing over the one remaining bare wire and the one with the small piece of heat shrink tubing. Apply the heat gun again.
This sounds more complicated than it is to actually do.
Aug 12, 2014 | Gateway Ac Adapter Liteon For Pa-1650-02...
Speaker wire sheath has split
There are a number of items you could use to cover (repair) the exposed wire. I agree the quickest repair would be to use electrical tape, everyone has it at home but I don't find it very durable. The easiest, most durable, waterproof, and coolest solution would be to use Bondic
Bondic The World First Liquid Plastic Welder Not Glue
I found it the other week at my Redmond's Home Hardware store and I keep finding things to use it on. It has a precise applicator and the flow of material is very controlled so it allows for very tidy repairs.
You could also use liquid electrical tape, it's messier but it will stick better than regular electrical tape
Apr 08, 2014 | X-1 x Interval 4G Waterproof Headphone...
Dymo 220P has a new cartridge but won't print
I should check that your new cartridge is identical to the old one. I have had a similar problem with blue plastic case cartridges, when my Dymo works perfectly with the clear ones. I have found that the blue ones do not have the gaps / notches at the bottom, but just the one! So I have cut off another slot, using the clear plastic cartridge as a template, added a bit of Dymo sticky tape because the new gap was too deep, and that was sorted! Good luck and mind your fingers! It looks to me like planned obsolescence!
Nov 14, 2012 | Dymo Labelmanager 220P Printer
Printing issue
You are welcome to contact our help desk. The numbers are at dymo.com. We can arrange a repair.
Dec 31, 2011 | Dymo LetraTag QX50 Thermal Label Printer
How do I change the size of the print on the label
Using the software that came with it modify the font settings.
Changing the Default Font Settings in DYMO Label Software Answer 299 ' Applies To DYMO ' Published 07/20/2005 10:16 AM EDT ' Updated 08/31/2010 05:05 PM EDTHow do I change the default font settings in the DYMO Label Software (DLS)?
Font settings can be adjusted for individual label templates and for the DLS application. Please note, changing the font settings for the DLS application will only affect the creation of new label templates. It does not change the font settings of any previously created and saved label templates.
Changing the Default Font Settings for Individual Label Templates in DLS
  1. Open DLS.
  2. In DLS, click and highlight the text on the label template.
  3. The tool bar above the label template allows you to change various font and justification settings. To change font type and font size you must click on the Font Settings icon: f_f.jpg
  4. Make the necessary changes to the font settings. The Sample field indicates how the text will appear on the label. Please note, the text will automatically shrink to fit if you select a font size that is too large for the address or text object on the label to accommodate.
  5. Click OK after making the necessary changes.
  6. Save the label template. Click on the File menu in DLS and select either Save or Save As. Selecting Save will save the label template with its existing name. Selecting Save As will allow you to enter a new name and create a new label template.
Mar 01, 2011 | Dymo LetraTag QX50 Thermal Label Printer
How to refill the ink?
There is no ink......the Thermal paper is sensitive to heat and turns black when it is heated.
If you use thermal paper the printer heats the paper to create your printed message. Some of these papers are side sensitive so be sure to feed it in right side up!
Sep 22, 2010 | Dymo LetraTAG Thermal Label Printer
Hi I'm wondering if the Dymo pocket will take a tape, so that I can iron labels on to clothing or even be stitched on. If so what would the cassette be called. Thanks
The Dymo label printer capable of printing iron on tape is the Dymo Letratag. There are a couple of model printers
Dymo Letratag - handheld model
Dymo Letratag - desktop model with qwerty keyboard
and the Dymo 18771 Letratag iron on tape is the tape cartridge available.
Jan 21, 2010 | Dymo LabelPOINT 100 Thermal Printer
The print on my dymo letra tag is very faint, how to fix?
The first thing you should do is check the batteries. Because the LetraTag requires heat to generate thermal printing, not ink, the batteries need to be well charged. Also, there is a small brush fitted to the inside of the lid of the cartridge cover, that is for cleaning the print head and roller. Remove it, dampen the felt tip with a little rubbing alcohol, and gently clean the print head and roller. You should find this will improve the print quality 100%
Oct 28, 2009 | Dymo LetraTag QX50 Thermal Label Printer
No longer printing - looks like its out of ink - what to do?
A thermal printer doesn't use ink at all. It uses a special heating element to heat the printing surface, which makes a special chemical in it turn black where it gets heated. If the unit doesn't have fresh batteries, the unit may not be able to produce the heat it needs to print. If it has fresh batteries and the correct cartridge, the unit needs to be replaced.
Oct 13, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Dymo Letra Tag
It runs on heat transfer. It probably needs new batterys. If youve been on a labeling spree you've most likel killed it.
Sep 24, 2007 | Dymo LetraTag 2000 Printer
51 people viewed this question
Ekse
Marvin
Marvin
