When you say headphones do you mean the music headphones, like speakers, because they go in the headphone jack in the computer while microphones go in the microphone jack. The microphone is normally a pink color and the headphone jack is normally green. If you already knew this try wiggling the microphone to see if there is a brake in the wire, if that dose not make it fissile in and out then its something wrong with the microphone its self and should be replaced
Think of the "headphone jack" as an OUT, while a microphone as an IN. Can't put something into an output.
You not only would need an IN, but the correct level input as well. Microphones require a preamp to boost the signal level to line level. Depending on your microphone (condenser) you may also need what is called "Phantom Power" to power the mic.
I hope this helps,
Magoo
Some computers have a special jack labeled line in. If your computer does not have a line in jack, you can use the microphone jack. You can then adjust the volume of the device in control panel under sound options. The headphone jack is only for output. I have seen some computers where you plug in a cable to the microphone jack and you will be asked what kind of device it is.
Please follow the below steps. On this image "E" is the headphone and speakers jack. You can insert the speakers here.
ComponentIconDescription
A. Speakers
Provide audio output when headphones or amplified speakers are not plugged in.
B. LCD panel release latch
To open the LCD panel, slide the release latch to the right.
C. Battery status indicator
LED blue - battery is fully charged
LED purple - battery is charging
LED blinking - battery charge is very low
D. Power status indicator
LED on - notebook is on
LED blinking - notebook is in Standby mode
LED off - notebook is off
E. Microphone jack
Plug a microphone into this jack. The built-in microphone is turned off when a microphone is plugged into this jack.
F. Headphone jack
Plug amplified speakers or headphones into this jack. The built-in speakers are turned off when headphones are plugged into this jack
I have the same speakers. It should have two plugs, one green and one pink. the pink plug is for a microphone. On the side of the speaker with the control knobs, you will find a headphone jack and a microphone jack. Unless you plan to plug a microphone into the pink microphone jack on the side of the speaker, you don't need to plug in the pink plug that goes to the PC. This is basically a microphone extension cord that runs through the speaker cord. That's all the pink plug is for. The green plug, on the other hand, is for your audio out. take the green plug and plug it into your computer's head phone outlet and you're good to go. You can use the speakers with any device that has a headphone jack. Just make sure you use the green plug, not the pink plug.
the simple answer is No. The long answer is your laptop/computers headphone output and mic input are completely separate on the sound card. Meaning there are no tie to the audio in on the heaphone lines, and vise versa on the mic/line in. Sorry to disappoint.
Welcome to the computer age. I looked up your HP W1907 monitor. It comes with a built in microphone and speakers but no audio jack for plugging in headphones. You will need to find an audio jack on your computer tower. Most new computers have audio and microphone jacks on their front face. In most cases there will be a picture of a microphone or headphones next to the jack to tell you what it is. If you can't find one on the front, look in the back. The audio jack is usually color coded green. I hope this helps you out.
I'll need more info on this problem: what type of connection do the headphones use? USB? Bluetooth? Classic audio jack?
..... Solution bellow applies in case of "ordinary" audio jack headphones. Also, check if your headphones have a built-in volume control (usually located on the cable). If that is the case, look for a Microphone On/Off switch if one exists. Step 1. Make sure that you've plugged in your headphones in the correct jack. These days, they are usually color-coded so Microphone should go be plugged into a red jack.
Step 2. Run "Volume control ["Start > All Programs > Accessories > Entertainment >Volume Control"] or double click the speaker icon in your System Tray if it's present.
Step 3. In Volume Control, activate "Options > Properties". Find "Microphone" and "Line In" under the "Show the following volume controls:" and activate them. Click ok.
Step 4. Maximize the volume on the "Microphone" and "Line In" slider.
