If I understand you correctly the compressor is short
cycling. The more it does this the worse it gets by causing the compressor to overheat. Sometimes the problem is because the condenser fan or evaporator fan being defective. Pull away from wall and remove cover over compressor unplug and feel top of compressor and if too hot to keep hand there keep unplugged but do
examine the evaporator and condenser fan to eliminate them as a reason. The most likely reason is start relay and or start/run capacitor and sometimes a worn out compressor.
Overload relay click here=>
67002527Run capacitor click here=>
65889-4Location Click Here=>
MBB1952GR Compressor ComponentsParts in that photo are marked as 10 overload/relay, 11 is the run capacitor and 3 being condenser fan motor. Condenser and evaporator fan motors do not always stop completely when bad so make sure both run while compressor is running. If this has been helpful please rate if you have more questions please let me know, Thanks
Sea Breeze
